Visaton FRS8-8 Enclosure Design Help
Old 14th August 2019, 09:12 PM   #1
imk is offline imk  United Kingdom
Default Visaton FRS8-8 Enclosure Design Help
Hello,
I have a pair of visaton FRS8 8 ohm, i need a home/enclosure for and I am having problems even getting going on the project as online enclosure calculators i have tried have issues with is specked Qts of 1.04.
All i am looking to make is a pair of small desktop/pc speakers; can someone help me with a bit of a design help please?
Even just the unported volume or ported volume plus dia/length, would be a major help. The rest i think i could figure for myself :-)
Many thanks in advance imk
Old 14th August 2019, 09:34 PM   #2
GM is offline GM  United States
GM's Avatar
With a 120 Hz Fs/1+Qts, make the biggest box you can tolerate since it will technically still be way too small if vented, use pegboard or similar for the back plate and stuff it with polyfil or similar to 'taste'.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 14th August 2019, 10:04 PM   #3
GM
GM
Many thanks for the post it is good starting point.
I was evening thinking of buying a pair of these CUBE 11cm boxes and using the top as the back and screwing it on. So i expect your saying drill a bunch of holes in it, stuff with poly and hope for the best?
CUBE Square plain wooden box with removable lid - choice of sizes (WB20-23) | eBay
Old 14th August 2019, 10:32 PM   #4
GM's Avatar
You're welcome! Well, ideally need at least ~70% of its area open to make it somewhat aperiodic [very leaky vented] to 'bleed off' a bit of its 'Qness', but not so little/much damping that it sounds too 'boomy'/'lean'. Ideally the back would be some window screen tightly stretched over the opening and it needn't be the back for that matter in case you want to put them against a wall.
GM
Old 15th August 2019, 08:14 AM   #5
GM
GM,
Then would it make more sense to make a T-line type enclosure for these FRS8's
Old 15th August 2019, 08:39 AM   #6
mjf is offline mjf  Austria
i built the frs8 into a 1,5 liter closed box (try out 1l.......2l), stuffed with polywool (or cotton wool, lambs wool,.........).
experiments: drilling holes into the back of the box
damping material (carpet,...) onto the walls inside
Old 15th August 2019, 09:06 AM   #7
GM's Avatar
Originally Posted by imk View Post
GM,
It's what I'd do.
Assuming a SS amp, tune to ~120/1.04 = ~115 Hz with a total net Vb = ~4x Vas, stuff to 'taste'.
GM
Visaton FRS8-8 Enclosure Design HelpHide this!Advertise here!
surround with Visaton FRS8, measurements and design. ▀art West-VL. Full Range 28 14th January 2013 01:48 PM
Visaton FRS8's in Needles Gregoire Full Range 3 12th January 2013 03:08 PM
Bipolar Loudspeaker with Visaton FRS8 8 ohm Esa˙ Cardoso Full Range 7 19th February 2012 06:08 PM
Visaton frs8, frs8/m with cyburg ? Redge Full Range 12 15th January 2011 02:59 PM
Visaton FRS8 line array & W170S Miha Multi-Way 16 3rd November 2004 11:24 PM
Copyright ©1999-2019 diyAudio
