need advice.
need advice.
Old 13th August 2019, 02:35 PM   #1
rbs is offline rbs  United States
Default need advice.
I would like some opinions,on the best 8" full range speaker. What 8" speaker has the clearest mid range on vocals. I listen to mostly female jazz vocals. Thank you for any expert opinions.-RUDY
Old 13th August 2019, 03:00 PM   #2
twocents is offline twocents  South Africa
twocents's Avatar
need advice.
It's been asked before - maybe you will find some clues here:
What's the best 8" fullrange that you've heard?
Old 13th August 2019, 09:00 PM   #3
DaveCan is offline DaveCan  Canada
DaveCan's Avatar
That's always a very tough question as it's so driver, enclosure, room, amp, source depended for a good variety of single FR drivers. I haven't heard a lot of the 8" full range drivers, but of the three I have heard I'd say the Fostex 206 ESR was the best. I forget the enclosure but they were powered by a pair of 45 tube amps. Haven't heard any of the really expensive stuff in that category, just the regular Fostex fe 206, the ESR 206, and and perhaps a pair of Radio Shack ones way back when I was a teen in a pair of speakers I had.
Dave
Old 13th August 2019, 09:27 PM   #4
Mattes is offline Mattes  Germany
Mattes's Avatar
Hi Rudy,
before I finally bought my FERTIN 21M8EX, I´ve heard (and still have) several FR drivers, but your question is hard to answer.
If you give a few more details (budget, planned application, room, electronics), it would be a bit easier to suggest a few drivers...
All the best
Mattes
Old 13th August 2019, 09:42 PM   #5
Default plan to use speaker
Under $200 each,18ft x 12ft living room, Luxman 50watt SS amp,JBL 077 tweeters for extreme high end. thanks for your comment-RUDY
Old 14th August 2019, 08:27 PM   #6
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
need advice.
The best drivers for mid and female vocals are all smaller than 8”.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th August 2019, 09:48 PM   #7
GM is offline GM  United States
GM's Avatar
Yeah, to adequately cover a male's voice requires an octave on each side of a ~100-16 kHz BW, so for even distribution of power:
[50-32,000]^0.5 = ~1265 Hz
SoS/pi/~1265 = ~3.41" effective diameter or ~5.5" frame and go larger or smaller depending on how much lows Vs highs 'bias' you prefer.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
need advice.Hide this!Advertise here!
Advice on MTM radal Multi-Way 3 21st January 2016 02:33 PM
T-amp advice please. Jolly John Class D 1 10th March 2015 09:20 AM
Need some advice where to install LED, also power socket advice. Mull3t Construction Tips 14 28th May 2012 04:32 PM
advice regarding PSU spendorspain Power Supplies 2 30th July 2008 07:57 AM
Poster in Musical Instrument forum needs bridging advice on BrianGT 4780 advice moving_electron Chip Amps 0 16th February 2005 12:37 AM
Copyright ©1999-2019 diyAudio
