A staggered horn.
A staggered horn.
Old 9th August 2019, 05:41 AM   #11
GM is offline GM  United States
GM's Avatar
Not an acoustic term, but works for describing how this particular one looks.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 9th August 2019, 06:05 AM   #12
GM's Avatar
Originally Posted by Scottmoose View Post
Using two differently tuned horns may average out deviations e.g. harmonic modes.
Well, if he did it acoustically like the divided 12" concrete former tube I posted about on the original FR forum and one other [here?] is tuned to Fs and the other is tuned to fill in the dip ~ a half octave above it [~1.4142x Fs], so functions acoustically similar to a double bass reflex [DBR] to increase power handling all the way down to tuning [Fb].
GM
Old 9th August 2019, 08:47 AM   #13
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Ah. Obviously not one of my brighter moments (re the appearance).
I suspect it'll be tuned more or less in that way.
Re the question about Japanese design practice with wideband drive units, not without writing something approaching book length and I don't profess to be an expert on it (or anything else for that matter). Short version, for a variety of reasons there is somewhat less concern with a flat (or even a particular target) frequency / amplitude response. Likewise, even enclosure resonance modes per se are not automatically viewed as a great evil providing they don't significantly impinge on, say, pitch, or help provide a desired tone. Certain resonant softwoods are prized in some circles for that reason.
There is also a much wider attention given to system design as a whole than is often applied in the west. Drivers are often designed assuming a particular broad type of amplifier or in the absense of said, that appropriate alternate means are applied to achieve similiar. Compact enclosures tuned very low, but without necessarily having large amounts of gain (except, in some cases, a bit of a kick around Fb / Fp) are often popular, because many are used in small, thin-wall apartments. Narrow baffles are also popular -partly reducing edge diffraction, but mainly so the damn things can fit into a small space with the least practical intrusion. Extreme example: take 1 x 3in Fostex drive unit and end-load a compact 12ft long horn with it for mini HT. Tall is often seen as good for the same reason: it doesn't eat into floorspace. T/S filter theory is not used to quite the extent it is elsewhere; some aspects but it lacks the near-blanket dominance it has in other regions. And so on.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
A staggered horn.Hide this!Advertise here!
77Hz bass horn, Azura and GOTO horn project starts atilsley Multi-Way 6 9th November 2016 09:01 AM
Fitting "Pentawatt" and similar "staggered leg" chips in perfboard lmaurits Chip Amps 6 6th May 2014 07:55 AM
Sony "staggered" twin TDA1541 PlasticIsGood Digital Source 23 1st January 2013 07:08 PM
12" full range on a backloaded horn, BIB, tappered quarter wave or other horn boxes? c3conv Full Range 1 27th July 2011 05:37 PM
Sloped or staggered D'Appolito Fred75 Multi-Way 2 12th August 2010 07:48 AM
Copyright ©1999-2019 diyAudio
