Whats the SPL at source (@0 m) when SPL is 90dB@1M?
Old 17th July 2019, 08:59 AM   #11
David McBean is offline David McBean  Australia
Originally Posted by JMFahey View Post
In theory, SPL should be infinite, and you should have an infinitesimal source, thatīs why itīs called a "point" source.
"A point source is a small source which alternately injects fluid into a medium and withdraws it." ~ Harry F. Olson - "Acoustical Engineering"
In the example considered earlier the source was assumed to have a surface area of 5 cm2, equivalent to a spherical "point source" of radius 6.3mm (less than 0.37 wavelengths at 20000 hertz). The SPL of 134 dB was calculated at the surface of this source.
www.hornresp.net
Old 17th July 2019, 09:11 AM   #12
Originally Posted by wonderfulaudio View Post
The question occurred to me while trying to find the SPL as I move closer to the driver.
SPL2 = SPL1 + 10 * Log10(S1 / S2)
Given:
SPL1 = 90 dB
S1 = 4 * Pi * 1 ^ 2 m2 (surface area of sphere of radius 1 metre)
S2 = 5 cm2 = 5 * 10 ^ -4 m2
Then:
SPL2 = 90 + 10 * Log10((4 * Pi) / (5 * 10 ^ -4)) = 134.00 dB
www.hornresp.net
Old 17th July 2019, 07:03 PM   #13
steveu is offline steveu  United States
Sound Fields - acoustic glossary - article
"Near Sound Field, that part of a sound field, usually within about two wavelengths of a noise source, where there is no simple relationship between sound level and distance, where the sound pressure does not obey the inverse square law and the particle velocity is not in phase with the sound pressure.
Near Sound Field Definition IEC 801-23-29, sound field near a sound source where instantaneous sound pressure and particle velocity are substantially out of phase"
Web search for "near field effect" and you will find you tube videos and more.
Whats the SPL at source (@0 m) when SPL is 90dB@1M?Hide this!Advertise here!
Best 10"sub 89-90dB gigigirl Subwoofers 12 14th April 2017 05:39 PM
Whats the best Digital source ? thermal runaway Digital Source 21 22nd November 2009 07:07 PM
90db in 10L f3 of 35hz !? oaristys Subwoofers 19 13th July 2009 11:18 PM
7W enough for 90dB speakers? kacernator Tubes / Valves 26 21st January 2008 04:48 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
Copyright ©1999-2019 diyAudio
