Help me to design transmission line for TG9FD-10-04
Old 20th July 2019, 03:15 PM   #11
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Nice work! This speaker can probably use a BSC with 1mH and 6.8Ohm for more balanced treble/bass. Play around with the resistor though as back wall bass reinforcement may reduce the need for a larger R.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 21st July 2019, 12:50 PM   #12
gadut is offline gadut  Indonesia
gadut's Avatar
finished 1 enclosure today with 1 side panel removable for stuffing access. initially it should be placed on the rack beside tv, but the room sucked all bass even bigger alpair 10p in minionken get the same no bass. but when it's moved to the corner then it shines
@X
it simple enough to play with my tone control bass-mid-treble, i'm searching now on aliexpress for integrated class d with tone control and maybe extra bluetooth
AD1865||DCB1||FW PSU||J2||M2||SIT L'Amp||Open Baffle
Old 21st July 2019, 04:14 PM   #13
perceval is offline perceval  Taiwan
perceval's Avatar
No wonder with that wall behind the speakers.
To get bass, you would need a speaker that outputs with the vent right next to the floor, front facing preferably.
Old 21st July 2019, 06:33 PM   #14
Bare is offline Bare  Canada
Interesting build.. But frankly expecting Any bass out of 2" cones is 'optimistic' if not delusional .
Gotta fit a decent Sub OR use Large, good Quality drivers.. has been my experience, after ~50 years of DIY adventures.
While here: WHY do these teeny drivers ..all... claim to be Twice the size their cones actually measure at ??
About as convincing as claiming that one's Member is 12" long
Old 21st July 2019, 10:14 PM   #15
lung is offline lung  Germany
while waiting wood filler dried on my subwoofer build, i started to build X design which i think it's simplest one. rabbet join result is getting better now
Made this speaker 2 years ago. Sounds very good with TC9 8 Ohm.
For bufflestep kompensation i used 1 mH and 10 Ohm as
xrk971 recomends.
Thanks for sharing.
Old 22nd July 2019, 03:03 AM   #16
Got Foam?
xrk971's Avatar
Gadut and Lung,
Both of you made a nice box for this speaker. I like how compact it is - works well for desktop or bookshelf.
Gadut, make sure you use gasket for side panel. Small pinhole leaks will destroy the bass. Like a leaky finger on a flute playing low C.
Old 22nd July 2019, 08:36 AM   #17
gadut's Avatar
xrk971 recomends.
Thanks for sharing.
nice build
Originally Posted by xrk971 View Post
Gadut and Lung,
that's why i put papertape inside but yeah not fully-sealed yet, i will put same papertape on outside left side panel which hopefully will seal the air
the bass is very thin if not placed on the corner which look like too low port tuning, my internal dimension is 4x13.5x9.5 inch a bit different from original ginl design due to my rabbet join. is this big issue? I will try to increase or decrease port length if it can change the sound
Old 22nd July 2019, 11:48 AM   #18
Got Foam?
xrk971's Avatar
Tone controls may not have the right filter high-shelf attenuate function that a classic BSC with a 1mH coil and resistor in parallel have. Basically you want a flat -3dB to -5dB shelf above 900Hz or so with a -6dB/oct slope at the filter frequency. Bi-quad EQ from a DSP can also do it of course.
Try making port a bit shorter - however, this speaker just isn’t a bass generator. A 0.40X Karlsonator has more full bass if you ever want to try that.
Old 23rd July 2019, 01:12 AM   #19
gadut's Avatar
Try making port a bit shorter - however, this speaker just isnít a bass generator. A 0.40X Karlsonator has more full bass if you ever want to try that.
I have several inductor starting from 0.5 to 3.3mH but the problem is that all the labels are gone. i might start from the smallest one
indeed what bass do you expect from that tiny driver, but my creative T20 with 2.5" has more slam but tuned higher for sure. just want to maximize the output from MLTL because the cone already jump in-out but lean bass
Help me to design transmission line for TG9FD-10-04Hide this!Advertise here!
transmission line design contractsman Full Range 2 24th June 2019 03:09 AM
Transmission line Omni speakers? Duevel Planets clone with transmission line? DeeLuxx Multi-Way 57 12th February 2019 12:32 AM
Transmission line design Cayd Multi-Way 30 27th February 2015 10:42 PM
Transmission line box, is this a ok design? spanerman Subwoofers 13 11th August 2009 10:48 PM
Transmission line design?? Dominick22 Subwoofers 1 15th September 2006 07:24 PM
Copyright ©1999-2019 diyAudio
