Full-range Driver for Transmission Line Cabinet - Recommendations?
Old 24th June 2019, 03:06 AM   #1
contractsman is offline contractsman  United States
Default Full-range Driver for Transmission Line Cabinet - Recommendations?
I'd like to install a full range driver into a Sony SS-TL1 Transmission line speaker cabinet (pictured below).
Any recommendations for a likely compatible 6 1/2 driver?
(This was a Goodwill find I couldn't resist for $30 {it's an Audio Karma sensibility}. I re-foamed the original cheap drivers and the sound is OK but unremarkable... except for the bass performance which is amazingly extended and deep... especially considering the cheap stamped basket mid-woofer, so now I MUST leverage the aesthetic and engineering of this REAL TL cabinet!
Cabinet Specifications:
*The overall cabinet size is 9 1/8" wide X 36 5/8" tall X 11 1/2" deep.
*Wall thickness is about 5/8"
* I guess this is considered a single-fold. The interior looks just like the illustration with a centered vertical wall inside running the full cabinet width and running parallel to the driver faces. (no angled corners or diagonal bias). See illustration below.
So any suggestions?
I could potentially experiment with more than one driver - especially if I purchase on eBay. Another source is PE of course. I really believe their Tang Band drivers offer great value and they have at least three options. (They have a great engineering / materials sciences story and the Asian production efficiencies).
Tang Band W6-2313 6-1/2" Coaxial Full-Range Woofer
Dayton Audio PS65LP-4 6-1/2" Ultra Efficient Low Profile Full-Range Driver 4 Ohm
Tang Band W6-2144 6-1/2" Paper Cone Full Range Driver 8 Ohm
The house brand, Dayton also seems like a good driver:
Dayton Audio PS180-8 6-1/2" Point Source Full-Range Neo Driver
OK. I read enough here about TL designs to realize I don't know WTF I'm doing... like this thread:
Need help designing my first TL speaker
But I'm still hoping, there's some good starting point drivers to experiment with.
Original woofer with bad foam
Re-foam then add gasket
Restored to original but these REALLY need better drivers! Seems Ideal for a Full Range Driver
Manufacturer's manual
This is the interior
Old 24th June 2019, 04:56 AM   #2
GM is offline GM  United States
GM's Avatar
Greets!
Need to know the vent dimensions and would like to know the driver offset from the closed end.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 25th June 2019, 07:30 PM   #3
DrBoar is offline DrBoar  Sweden
DrBoar's Avatar
A suitable driver should have a decent X-max (say 3mm or more) and a Fr below 50 Hz and a Q around 0.3. That is with parameters as a driver for bass reflex driver: The two suggested Tangband look OK spec wise.
Old 25th June 2019, 08:23 PM   #4
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Given that it looks like they taper to the back, we would need to know the placement of the partition and the height of the opening at the top.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th June 2019, 10:29 PM   #5
Great input. I took some measurements:
Vent Dimensions are: 7.5 X 2.625 (2 5/8) = 28.125 square inches
The vent offset from the bottom is about 0.625 (5/8);
The vent opening from the top of the cabinet it's about 31.75"
+Click the image to open in full size.
Driver offset from the top of the cabinet is about 6"
(about 1.25 from each side and 23.75 from the bottom)
Regarding the placement of the partition, I'll need to take some more measurements...
Great info on the TB drivers. I'm definitely leaning towards trying one of those or maybe even one of their highly rated 5" models. I will look at the specs you mention.
Old 29th June 2019, 04:26 AM   #6
GM's Avatar
OK, thanks!
FWIW/FYI/future reference, we normally work off cutout/component center lines and inside dimensions [i.d.].
Anyway, I've got enough info to get an idea what sort of specs we need, though can't sim any until we've got those internal dims.
GM
Old 29th June 2019, 11:07 PM   #7
GM's Avatar
Of this bunch, only the W6-2144 is in the 'ballpark'.
GM
Full-range Driver for Transmission Line Cabinet - Recommendations?Hide this!Advertise here!
Full Range TC9 Line Array CNC Cabinet fluid Full Range 947 13th July 2019 10:35 PM
Full-Range Transmission Line design for TB W8-1808 mjhara Full Range 22 20th November 2016 10:12 PM
Full Range Driver Recommendations tkdbrusco Full Range 4 17th August 2015 04:38 AM
Need recommendations for a 6-1/2" full range for a line array sdep777 Multi-Way 2 25th July 2015 11:46 PM
Looking for Full Range Driver Recommendations CarsonLere Full Range 10 14th July 2014 03:29 AM
Copyright ©1999-2019 diyAudio
