Full Range for Surround Center Channel?
Old 14th June 2019, 09:23 PM   #31
chrisb is offline chrisb
I’ve used singles of both A7.3 and A10.3 as centre channel (Lo passed as high as 100), and would definitely recommend the larger of the two if you can accommodate the enclosure size. Mine is a variation on one of the centre enclosures to which Dave posted a link to previously, with the front panel slanted up at 5dg.
Retired from active DIY
Old 14th June 2019, 09:40 PM   #32
johnsurnamerobinson is offline johnsurnamerobinson
I stopped 20 years ago sitting in the hot spot. Nowadays for me its mostly a/v. A friend who was part of Ozzy`s band found the same thing.Funny thing is I never thought I would get old.
Old 15th June 2019, 01:47 AM   #33
GM is offline GM  United States
GM's Avatar
Originally Posted by Veleric View Post
Given that, is a single driver the best choice, or two drivers?
Again, should all be identical across the front, but if must go smaller, then what can come closest in PRaT or at least in the critical 250-3500 Hz phone BW ['voice'] and in smaller HTs the CC may need a super tweeter to get enough off axis coverage on a three wide row, but I gather you won't have the baffle height for one if you need it, so academic.
In short, only a focussed over n' under is suitable for dual 'anything' for high speech intelligibility.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 17th June 2019, 04:15 AM   #34
Veleric is offline Veleric  United States
Okay, no progress yet on my center channel, but I got around to attaching all the wires on my new avr (Onkyo TX-RZ630) and ran the initial setup using the supplied calibration mic. My system is only 2.1 so far, as I'm using channels 6/7/8/9 for remote zones.
Anyway, was a bit surprised that after running the AccuEQ setup, it selected a crossover frequency of 40 Hz for my front speakers, and an LFP of LFE of 120 Hz. That seems like a lot of overlap doesn't it? My front speakers are MLTLs that with an F3 of about 43 Hz, so can reach down that far, but I expected that the two "crossovers" selected by AccuEQ would have less overlap. Is this expected? Is it reasonable/good?
Thanks,
Eric
Old 17th June 2019, 09:38 AM   #35
As long as your system has no nasty phase shifts at lf I dont see a problem.Personally have used subs with full range!! satellites in the past all w.as OK
Old 17th June 2019, 03:14 PM   #36
Eric, sounds like you’re early on your journey down the rabbit hole of multi-channel. Some interesting features on that RZ series. In my own case, adding small PLIIz front height speakers (Pluvia7 in top corners) and research surrounds (A5.2) made a huge difference in the overall sensation of space and, well being surrounded by the on screen events - Kings Landing “battle” scene, for example.
Although it looks like Onkyo have departed from Audyssey and adopted their own calibration / EQ function, unless the interface and manual setup options buried a few layers deeper than the auto mode, you can still adjust those crossover frequencies on the fly to find settings that may work better for your ears than the defaults. I chose the setting of 80Hz labelled as THX standard for the front row, and 120Hz for the peripheral surrounds.
Have you tried the phono input? While I’ve not seriously listened to my ‘table in probably 5 years, I did test it out on the NR830, and it was surprisingly non-hurtful.
I continue to be amazed at the amount of functionality and relative ease of use the designers of modern surround receivers can cram into a single box. I think we all know guys who’ve spent more money on snake oil infused speaker and interconnects than your unit cost.
Old 17th June 2019, 10:48 PM   #37
That's not the plan, but who knows.....presently planning to stop at 3.1!
Yes, the "manual" adjustments are still easily accessed, but I wanted to see what the auto mode came up with on its own. Actually, one of my main motivations for replacing my old stereo receiver with this unit was to be able to use the crossover to limit the low frequency inputs to my two front speakers. I was expecting the auto mode would cut them off higher. I may try 80 Hz for the fronts like you have set and see how I like that. The ironic thing is that I designed my front speakers to reach down close to 40 Hz, and now I've bought a sub and crossover and plan to prevent them from trying to. It makes me feel a little dirty somehow...
Haven't and probably won't. I haven't had a turntable since about 1985 and at Christmas gave all my albums to my daughter!
Pretty cool indeed for cheapskates like me!
Old 18th June 2019, 07:18 AM   #38
GM's Avatar
These systems do time delay correction, so where there's a need it will 'gap' the XO same as is done with prosound horn/woofer[s] or similar speakers to get 'close enough' delay added when they aren't physically aligned.
GM
Full Range for Surround Center Channel?Hide this!Advertise here!
center channel crossover point? full range perhaps rockironwebb Multi-Way 10 31st July 2012 10:14 PM
Full range as Center channel thisisvv Full Range 13 20th July 2012 01:33 PM
Full range center channel spartakus31 Full Range 3 1st May 2011 02:25 AM
Frequency range of the human voice & full range center channel speakers jwmbro Multi-Way 31 20th January 2008 03:07 PM
Copyright ©1999-2019 diyAudio
