cornu and akabak
cornu and akabak
Thread Tools
Old 1st June 2019, 10:04 PM   #1
johnsurnamerobinson is offline johnsurnamerobinson
Default cornu and akabak
Legend has it that somewere on this site a Don Hills posted an Akabak script to model a cornu horn
problem is more posts here than stars in the galaxy !!!
if some kind person knows where its at (or knows how to find it) please provide link
so far I have looked in foam core but found ziltch (xrk971 says its in there someware)
must be a better way than wading through thousands of pages of posts
Old 1st June 2019, 10:10 PM   #2
KaffiMann is offline KaffiMann  Norway
Fanatic
KaffiMann's Avatar
cornu and akabak
... What, you mean this?
Foam Core Board Speaker Enclosures?
Took me like 15 seconds of intensive search action.
Old 1st June 2019, 10:36 PM   #3
Yeah looked in there still cant find mr Hills script:- lots and lots of pages and posts!!
also could have simply missed it???
Tried cornu,hills.akabak as search terms
By the way Im not being lazy just wondering best way how to find these things on such a huge site.
But also I am actually interested in designing and building some cornu horns
Old 1st June 2019, 10:45 PM   #4
Fanatic
KaffiMann's Avatar
cornu and akabak
The script is in the link I posted.
I'm not saying you're lazy, but maybe you're overcomplicating your search in order to get to your goal.
In this instance, I wrote only two words, "akabak" and then "cornu", search for "posts" scroll down looking for links to the post from Don Hills.
The key work is "akabak" since that is specifically what you're after and it should therefore be the first word in the search string, "cornu" would sort of be the second goal, and limits your number of "akabak" responses.
No sense searching for user posts normally, because the exact words you use in the search string might not refer directly to the information you're after. Sometimes better to look for a "pointer" in the right direction.
Old 1st June 2019, 10:54 PM   #5
The reason the script would be so usefull is the drive units are unknown brand currently mounted in
small plastic bass reflex boxes (computer speakers) but sound ok!!
I would have to measure all the T/S parameters myself and it would be nice to be able to model
the new enclosures myself with akaback (beginner level) but keen to learn
so mr Hills script would be very usefull
Old 1st June 2019, 10:59 PM   #6
Yes thats what i want thanks loads
Obviously i must be going blind
Thanks loads Kaffiman you are a diamond
8 hours on line and you found it in minuets
Old 1st June 2019, 11:08 PM   #7
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
cornu and akabak
Now you just need an old computer to run Akabak or VM in a newer 64bit computer. Good luck!
XRKaudio Store // Manufacturer’s Forum
Old 1st June 2019, 11:17 PM   #8
I have spare old vista 32 computer which seems to run akabak ok I just need to learn akabak
You guys on this site are great!!!
  Reply to this post
cornu and akabakHide this!Advertise here!
Thread Tools
Degenerate Mei = Extreme Cornu? jetlag9 Full Range 1 29th November 2017 06:01 PM
can a Cornu rescue the CHN-70 ? Bigun Full Range 6 5th January 2017 10:49 AM
CNC plans Spiral Cornu Anglo Multi-Way 11 27th March 2009 07:34 AM
Cornu Clones MuaDibb Full Range 4 21st February 2006 03:04 PM
suggestions for The Cornu TML ksl Multi-Way 17 16th July 2003 01:40 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
