Can I build sometime similar to Voxativ 9.87?
Old 23rd May 2019, 02:20 AM   #1
ttan98 is offline ttan98  Australia
Default Can I build sometime similar to Voxativ 9.87?
I found this system Voxativ 9.87 costing about US$40,000. You guys think a speaker system can be built to sound similar to this and I DON'T mean a clone. The website is Voxativ 9.87 SYSTEM.
One image and tech spec are attached.
Initial Thoughts
Full range driver already available: Tang Bang w8-1808 or 1772 or equivalent or similar
Ripole construction: Readily available.
It can be built based on combo passive xover and solid-state driven ripole OR active(DSP) xover. My initial thoughts it will sound quite good and outlay costs low or quite manageable. If not please explain. Thanks for your input.
Old 23rd May 2019, 02:59 AM   #2
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Voxative drivers are very pricey… my take on te W9-1808 & the 1772 is that they are overpriced for the sonics. My preference of the 2 is the 1808.
I hav eyet to see a Voxativ let along hear it, but you will probably need something better than the TB.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd May 2019, 03:18 AM   #3
dave
The Look of 9.87 is achievable ask a carpenter or craftsman to make one, less $5000/pair? A lot of leftovers for drivers. The main thrust of this project is to build a high-quality sounding system with adequate aesthetics, look is NOT a priority.
Better quality Full Range what brand/model do you suggest/recommend?
Old 23rd May 2019, 03:43 AM   #4
frugal-phile(tm)
planet10's Avatar
I have directly compared the TBs to the Marl Audio Alpair 10s which i prefer by a sizable margin. EnABLed of course.
dave
Old 23rd May 2019, 04:31 AM   #5
dave
went to Mark Audio website I CANNOT find this model: Mark Audio Alpair 10s, there are 10M and 10P?
Old 23rd May 2019, 05:24 AM   #6
frugal-phile(tm)
planet10's Avatar
The Mark Audio website is very out-of-date. The current Alpair 10s are the A10.3 (metal) and the A10p (paper).
Madisound has the T/S data, Drive drawings at frugal-phile.com.
dave
Old 23rd May 2019, 06:23 AM   #7
dave
ALternative name from Madisound:
Markaudio Alpair-10M Grey 6" Full Range Gen 3 or in short A10.3
Old 25th May 2019, 09:19 PM   #8
Mattes is offline Mattes  Germany
Mattes's Avatar
sure it can be done. W-1808 is a good start for the money in my opinion. Of course, there are alternatives to the Voxativ drivers, have a look at Seas Exotic, EMS, Supravox, Fertinacoustics, search for remaining Feastrex or chase perfect Coral Beta 8... and many more.
What is "better" in the end will of course depend on compromises chosen and will be a subjective matter - objectively such system, judged on measurements, will be easily beaten (you´ll find some Voxativ third party measurements in the net as well, not the makers fantasy data). You´ll also find a lot of info on a ripol woofer, that should be easy and has been done.
However, keep us informed of your thoughts and choices!
All the best
Mattes
Old 25th May 2019, 10:38 PM   #9
Another approach would be to build a vented bipole(down firing) with 2*Alpair 10.3 back to back(currently $85 each at Madisound), will give you a total of 94dB @ 4 ohm.
Old 26th May 2019, 12:18 AM   #10
BTW is offline BTW
Another option... try the fullrangers from lii-audio.com
Beautifully made Chinese clones of the Coral drivers.
Can I build sometime similar to Voxativ 9.87?Hide this!Advertise here!
Portable subwoofer build with JBL Atlas 3" or similar Xappys Subwoofers 6 24th September 2018 08:07 PM
Suggested first speaker build please; AN-E’s or similar ? itskeith Full Range 11 4th January 2017 02:32 PM
Voxativ Pi2 vkung Elekit 0 16th February 2016 06:31 PM
I think I want to build a TH for bass, Cubo Sub or similar Jimmy154 Subwoofers 22 16th February 2012 03:15 AM
How to build speaker similar to Aerial CC5 FrankK Multi-Way 2 25th November 2004 06:35 AM
Copyright ©1999-2019 diyAudio
