New DMA90-8 3.5in Al cone dual magnet
Old 22nd May 2019, 02:15 PM   #11
perceval is offline perceval  Taiwan
perceval's Avatar
I also remember how many hours Mattes spent on his flowers...
I thought you were already a busy man, X!
Which woofer do you plan to use with that Dayton driver?
But going the Mattes / Transfi way is tempting indeed....
Old 22nd May 2019, 03:20 PM   #12
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
I would use basic paper faced foam core so much easier to cut. My son was asking for a set of speakers for his room and I thought this might be interesting to let him help. Probably my dual Tang Band 5in XKi subwoofer that’s built already.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 30th May 2019, 02:34 PM   #13
Got Foam?
xrk971's Avatar
I received the drivers the other day. They are well made but note that the basket is plastic and not cast aluminum as it sort of appears that way. It has a large suspension with good support. The diaphragm and dustcap are both aluminum. I am not crazy about how large the square plastic bezel appears though - the lack of the 4 corner bevels seems to really make the driver look bigger than 3.5in compared to how small a TC9FD is. OTOH, mounting them flush in a line array simply requires a long trench rebate vs 25 beveled corners per side. A snap to assemble for a line-array as they would stack touching each other and leave no gap on the corners like a TC9FD would.
Still need to listen to it though.
Old 30th May 2019, 03:06 PM   #14
perceval's Avatar
Cool. Thanks for the feedback.
I still need to order the new SBA... forgot to do it.
Then we can have a contest!
New DMA90-8 3.5in Al cone dual magnetHide this!Advertise here!
Midrange (cone driver) horns; low relevance of magnet strength and Qts hollowboy Full Range 7 30th March 2019 04:23 AM
Anyone knows about this dual magnet TC9 clone? perceval Full Range 3 21st April 2017 11:24 AM
no moving coil no fixed magnet and no cone simeon w Planars & Exotics 49 13th November 2016 08:05 PM
Cerwin Vega 15ATW Cone Snaps to Magnet Krisfr Subwoofers 13 13th January 2015 10:02 PM
dual isobaric magnet interaction badman Subwoofers 17 23rd March 2012 02:05 AM
Copyright ©1999-2019 diyAudio
