Obtaining my White Whale (25 Driver IDS-25 Line Array Build)
Old 15th April 2019, 06:01 PM   #1
Nvphotos is offline Nvphotos
Default Obtaining my White Whale (25 Driver IDS-25 Line Array Build)
I've been sitting on the desire to build a pair of nearfield line arrays for the last 6 years after reading the work of Roger Russell and his column systems. 5 years ago I started building a prototype pair with cheap $1 Aurasound 3" with the end goal of building a separate, finished pair with Peerless TC9's. I never finished those after moving from NY to Florida for work.
To make a long story short... I finished them! Below are photos of the build. It has taken me several months to get them done and that was with having a cabinet maker build the cabinets. I never realised how many technical design decisions went into making these.
My goal was to have the best performance in a $3,000 budget (most of that went into the cabinets).
Old 15th April 2019, 06:21 PM   #2
(Once I figure out how to upload photos) Here is the prototype my cabinet maker made for approval before building the final cabinets. The construction quality was fantastic but I ended up making a lot of asthetic/performance changes. As you can see, we experimented with a full length grill option that would have been a full length sheet of perforated metal.
Old 15th April 2019, 06:23 PM   #3
Mooly's Avatar
Its easy
How to attach images to your posts.
Old 15th April 2019, 06:26 PM   #4
Thank you!
Old 15th April 2019, 06:38 PM   #5
The biggest change was to figure out if we could flush mount the drivers and which routing method worked best to allow the drivers to breath in the back.
Old 15th April 2019, 06:48 PM   #6
Here is the flush mount test as well as two styles of routing for the back of the drivers. I settled on the simpler of the two as it saved time and wasn't sure the extra meat for the screws was worth the extra complication.
Old 15th April 2019, 06:53 PM   #7
I had gaskets made on a water jet at a local rubber and gasket company to seal the drivers to the cabinet. I made the template in Photoshop. They cost $1.35 per x 50. Way better than cutting them individually by hand!
The flush mount in the cabinets were measured and tested the for these gaskets and remain flush.
Old 15th April 2019, 06:56 PM   #8
Making progress...
Old 15th April 2019, 08:12 PM   #9
Default How to find the sweet spot
Question for you line array guys before I return to posting build photos. How do position them to get a good sweet spot in the listening position? They have such a large sweet spot that it's like not having a sweet spot at all. I have no problem positioning point source speakers.
Is ironic, I built them to hear this huge sweet spot. Now I can't seem to find it because it's so huge.
Old 16th April 2019, 12:40 PM   #10
This is the rounded baffle edges we prototyped.
Obtaining my White Whale (25 Driver IDS-25 Line Array Build)Hide this!Advertise here!
30 Driver CBT Line array 30 Fountek FE87 driversper array T85matt Planars & Exotics 3 26th December 2016 06:51 PM
8ft Line array Build. T85matt Planars & Exotics 22 4th August 2016 07:14 PM
Short Line Array (line source) build perceval Full Range 226 4th January 2015 02:08 PM
Line Array with PHY Driver jpetek Multi-Way 6 9th December 2012 01:35 PM
I want to build a line array... Znyper Multi-Way 46 8th December 2007 10:45 PM
Copyright ©1999-2019 diyAudio
