Recomendation 8" full range that is also a good woofer for vented box
Old 9th March 2019, 12:12 PM   #11
wesayso is offline wesayso  Netherlands
wesayso's Avatar
Originally Posted by Johnsykes View Post
Thanks guys , as usual you gave me great advice and help but im going to go with a 2 way speaker , i think i will get better results for the same amount.
Good choice, John Sykes would like more power too .
Recomendation 8" full range that is also a good woofer for vented box-8104564834_5f38479961_b-jpg
Use Science to design your speakers and they will sound like a piece of Art...
Old 9th March 2019, 01:13 PM   #12
turk 182 is offline turk 182  Canada
??? are we talking to "the" John Sykes...?
got love Phil Lynott's hair!
Old 9th March 2019, 06:22 PM   #13
ultrakaz is offline ultrakaz  United States
Originally Posted by SONDEKNZ View Post
TBORZIC
I don't have any photos plans or drawings. I simply was invited around for a listen a year or two ago. I was impressed. I can say that the AN/E Cabinet copy was not heavily damped and that did not seem to matter. Perhaps it helped?
Your best bet is to follow the link yourself and explore VISATON. They provide loads of data, cabinet plan options and truly excellent service.
Here's the link again: -
B 200 - 6 Ohm | Visaton
Enjoy!
Not a whole lot of love for the B200 on this forum. Too bad as it is one of the better and more versatile 8" widebanders out there. I had mine in large BiBs and then in smaller sealed boxes and they sounded pretty good solo. Lots of plans at the website link above. Of particular relevance to the OP, there is a plan where they used the the B200 as a midrange(!). One could start with the existing crossover and with some tweaking eliminate the woofers (drop the highpass components) and run the B200 with the waveguided tweeter and it would make for wider/controlled dispersion 2-way.
Old 9th March 2019, 06:37 PM   #14
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Only in OB.
jeff
Old 9th March 2019, 06:40 PM   #15
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
The German-made VISATON B 200 might work for you.
The B200 has been used as a bas sdriver by Bert Dopenberg (2 in an OB WAW).
...it misses just that very top "air" or "sparkle"
I thot much the same thing when i 1st heard them, but added phase plugs seem to go a long ways to fixing that.
The B200 specified sensitivity is optimistic. They measure about 90 dB.
It also has a Q that usually means an OB, or a very large box (or a leaky one (ie aperiodic). I have 2 pair, already put them in an OB, so a big aperiodic box is my current plan. A box as small as the AudioNote probably has a substantial bump up at the bottom.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th March 2019, 06:47 PM   #16
Johnsykes is offline Johnsykes  Portugal
same name but different person , also a fan though.
Old 12th March 2019, 12:37 AM   #17
oon_the_kid is online now oon_the_kid  Malaysia
oon_the_kid's Avatar
This article might be of interest to you, although not exactly what you are asking for, they share a lot of common traits...
High Efficiency Speakers
Oon
Old 13th March 2019, 03:39 PM   #18
Godzilla is offline Godzilla  United States
Godzilla's Avatar
This driver measures similarly to the B200 for a lot less.
BG 20 - 8 Ohm | Visaton
Old 14th March 2019, 12:57 PM   #19
Vix is offline Vix  Yugoslavia
Vix's Avatar
Hi there!
Don't want to rain on the parade, but if vented box is the goal, I wouldn't recommend Visaton B200.
I am using it on the Open Baffle. Previously I have tried using in on various boxes, just for the sake of it, and the result wasn't pretty. Vented, its boomy. Sealed, it is much better but requires a huge box. Otherwise, tends to sound thin, so you may end up with a lot of BSC, which kills efficiency. Its top end is acceptable when phase-plugged, otherwise it beams. I heard that some local diyer was neither satisfied with the bass, nor top, and ended making it a two-way, which then defeats its purpose. Also, it is quite sensitive to amplifier output impedance, it likes it high So I am using it with Pass F2 amp.
P.s. I have also heard BG20. Cheap it is, it's worth the money, but not something you'd like in the long run...
Old 14th March 2019, 07:08 PM   #20
frugal-phile(tm)
planet10's Avatar
Worth repeating. With its highish Q any box you put it into needs to minimize or reduce the bas shump caused by the box. Hence its use in OBs where the dipole bass roll-off can be used to deal with the bass, or a REALLY big box (ie IB, use the next room as the box) to getthe box Q down to the unboxed Q (which is really near max-flat), but the most practical box would be aperiodic. Joe Rasmussen has done an aperiodic TL for it, as i have for a centre channel with B200 OBs as mains, or a simplier “holey” box as 1st proposed by Jordan and taken to higher sophistication by Perkins (PEARL). The last is th eapproach i am going to take — very similar to what i suggested and what Bigun did for his AN15.
The B200 can be made into a really decent driver, but the FA22 is in the same league and a lot easier to put into a box. Like almost all whizzer cone drivers it benefits from phase plugs. The PS220 is the other 8 i have heard that has potential (i only got a short listen, unlike the AN10 Classic that i listened to the previous week it did not have any objectionable issues). Tom in Florida really liked his in Sachicko (but his Sachicko have a parade of drivers going thru them), Decware did some smarmy mods to it and promoted it for awhile. Also given the way the PS220 gets made i worry about batch-to-batch differences.
I am a frugal-phile(tm) and have not had the opportunity to hear expensive drivers. The one ($6k) driver i heard was not very good. Lowther, Cube, Sonindo, AER, Voxativ — all close to hand-made big buck drivers that may or may not give a significant advantage to the best of the drivers in the “normal” price range. I believe they certainly get into the small improvements, exponential price class. At this poin ti am spending my money on mproving what feeds my speakers (currently bigish WAW).
dave
Recomendation 8" full range that is also a good woofer for vented boxHide this!Advertise here!
Cheap 8" full-range that works well in ~1cu.ft vented enclosure? CZ Eddie Full Range 33 21st January 2019 08:02 PM
Helper Woofer(s) for "punchy" FAST/WWW/SAW/etc. to go w/ Fane 12" full range drivers sbcrx007 Multi-Way 227 8th January 2018 09:56 PM
Full range recomendation ivan-UTN-ARG Full Range 9 23rd March 2017 08:47 PM
12" Full Range Speaker Recomendation Help c208driver Full Range 15 24th October 2013 02:04 AM
12" PA woofer in vented 3.5 ft3 cabinet = good idea? dbrose Full Range 37 20th February 2012 03:48 PM
Copyright ©1999-2019 diyAudio
