W6-2144 - Design time!!
Thread Tools
Old 7th March 2019, 04:46 AM   #11
eusubius is offline eusubius  Canada
Makes sense. So how do I translate those text files into charts and dimensions? I used to model everything in win ISD, but i don't know that I need to see every parameter here.
Does cross section shape matter? Or just that the box is the right height, matching your total volumes? Or is there a graphic program that I could punch those text files into?
Old 7th March 2019, 04:57 AM   #12
Figuring dimensions. Your sizes are roughly 2cu.ft. and 3cu.ft.
So an 8" wide box (external with 5/8" wood) can be 48" tall, 12" deep (2 ft3) - pushing it to 18" deep puts it at the larger size, 3 ft3! That's a good size indeed.
What do you figure the difference is in LF extension? Output?
Old 7th March 2019, 06:10 AM   #13
GM is offline GM  United States
GM's Avatar
Oops! So use to folks around here using Hornresp to a greater or lesser extent that the best way is to EXPORT/post the .txt file for download to HR's IMPORT folder, then load it into a proper RECORD to view, copy, save, rename, modify/whatever, so now's as good a time as any to install it: Hornresp
Official 'sticky' thread: Hornresp
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 7th March 2019, 07:09 AM   #14
freddi is offline freddi  United States
freddi's Avatar
real nice response GM with your 85L MLTL.
Old 8th March 2019, 12:13 AM   #15
CraigSu is offline CraigSu  United States
CraigSu's Avatar
Would someone be kind enough to post the Hornresp output/specs from GM’s .txt file for those of us who can’t run HR because we don’t have a Windows computer?
Avoid the paralysis of over-analysis: less Think, more Do!
Old 8th March 2019, 02:11 AM   #16
perceval is offline perceval  Taiwan
perceval's Avatar
HornResp works using Wine. Simple install.
Old 8th March 2019, 02:13 AM   #17
I plan to do plenty of wining once these speakers are built
Old 8th March 2019, 05:58 AM   #18
GM's Avatar
Well, I grew up back when 3 ft^3 was a bookshelf speaker and still have a hard time enjoying the tiny, super inefficient speakers popular today for other than talk radio and similar.
Once you get HR going you'll see the internal height [i.d.] is ~56.19" i.d., so WxD isn't very big and have all the other details except for one and that's the vent location. HR can only show it going out the bottom, but will actually be ~56.19*0.848 = ~47.65" i.d. down from the top. If you look at the Power/Chamber/Combined you'll see that there's a 'Path' length distance to account for this.
As noted earlier both are tuned to ~36 Hz, so ~flat to ~40 Hz with the main difference being increased acoustic damping with the larger alignment, which in turn boosts the very bottom end a little bit.
Note too that when viewing the design, do it in the Loudspeaker Wizard [LW] as it shows it with stuffing and has some advanced features if interested.
Note too that HR doesn't take any associated acoustic damping losses into account, so see a lot of sharp peaks, etc., that are either much reduced or not there is reality, so if simmed really smooth with lots of stuffing it will tend to be over damped if one uses the recommended amount, hence my recommendation to damp to 'taste'.
Anyway, sure you'll have Qs like everyone else figuring out HR, but it has a large HELP FILE with a FIND feature plus the official thread and of course me and others to answer specific Qs if you can't find it on your own.
GM
Old 10th March 2019, 04:56 AM   #19
GM's Avatar
Yeah, it's got good specs for a RCA vintage style 'HIFI' speaker.
GM
Old 10th March 2019, 05:36 AM   #20
Ok, I'm learning more about Hornresp! Installed... Finally got both records imported to compare...
Question GM; why the big peak at 40hz in your design? The other looks perfect/flat.
(Btw started breaking these in... They sound beautiful already! Imaging... Bam! )
(PS bonus points if you can tell me what the little yellow drivers are)download_20190309_213531.jpeg
W6-2144 - Design time!!Hide this!Advertise here!
Thread Tools
Tang Band w6-2144 driver vs dayton audio ps180 impressions or thoughts? Jeffrey 01 Full Range 5 5th June 2017 07:51 PM
1st Time Boombox Cabinet Design Questions Tom2112 Multi-Way 6 21st February 2017 07:22 PM
I think its about time for me to design my first Transformer tube amp.. thedoci Tubes / Valves 8 7th December 2015 06:00 PM
The Best Valve Amp Design In Modern Time: Poll Candidates Eddiegnz1 Tubes / Valves 31 5th December 2013 11:28 PM
22.5792 MHz crystals (also 26.2144) danville Swap Meet 0 16th June 2004 12:46 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
