Cheap 8" full-range that works well in ~1cu.ft vented enclosure?
Old 21st January 2019, 03:37 AM   #31
freddi is offline freddi  United States
freddi's Avatar
I suspect removal of the whizzer improves BG20's off axis response moreso than its on-axis. Without the whizzer, its something like a poor man's B200 response-wise
graph of BG20 sans whizzer from Visaton forum 0, 15, 30 off axis
graph of stock BG20 "yellow" (~on speaker center axis) in Karlson Twelve / "K12"
(the aqua trace is an Eminence Beta10cx woofer without any network - IIRC)
it would not hurt to roll in a helper tweeter
Old 21st January 2019, 11:53 AM   #32
LeifB60 is offline LeifB60  Sweden
Listen to this ! YouTube
I have listen to TLQW and that isnt bad. Detail bas and midrange.
Maybe better bas then 50 liter BR.
Old 21st January 2019, 07:26 PM   #33
GM is offline GM  United States
GM's Avatar
Add stuffing to the BR to get essentially the same IF the BR+ vent internal volume [Vb] is identical to the TL's. Normally though, the TL is a lot bigger for a given tuning, so will obviously be a bit 'fuller' sounding than the BR.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 21st January 2019, 09:02 PM   #34
Yes indeed. Fuller sound.
Of cours it is a taste i prefer.
Make BR if that is right for you.
Cheap 8" full-range that works well in ~1cu.ft vented enclosure?Hide this!Advertise here!
Vented for full-range a no-no? cyberstudio Full Range 27 5th April 2018 02:10 PM
Speaker enclosure build - 6.5" full range drivers darrylis Full Range 50 23rd October 2016 05:30 AM
Full Range Voice Range single speaker and enclosure loninappleton Full Range 23 9th May 2014 12:14 AM
Recommend a 3" full range for a very small enclosure audionut44 Full Range 21 26th March 2014 11:55 AM
6" or 6.5" Cheap Full Range for Rock'nRoll? Destroyer OS Full Range 19 4th June 2012 02:30 PM
Copyright ©1999-2019 diyAudio
