Bang for the buck
Bang for the buck
Old 9th January 2019, 06:52 PM   #1
jimmyjazz is offline jimmyjazz  United States
Default Bang for the buck
I'm just getting into the DIY loudspeaker game and the driver choices are overwhelming. I'd love to hear suggestions for brands or specific drivers that really ring the bell when it comes to performance at a given cost. I've looked at a lot of Dayton Audio drivers on Parts Express, and it doesn't seem like they get topped too often, but any other suggestions would be welcome. My main priority is small woofer drivers, with the expectation that low frequency extension is likely limited, but any other general thoughts are welcomed. Thanks!
Old 10th January 2019, 01:08 AM   #2
mikejennens is offline mikejennens  United States
mikejennens's Avatar
Bang for the buck
Mark Audio definitely deserves a look.
HiFiMeDIY T3 amp, FiiO DAC, HP Laptop source, Paul Carmody's Sunflowers and Core Two-Ways, Jeff Bagby's Continuums, Bjorn's TABAQs with the Dayton PS95 ... and a set of 60 year-old worn out ears from 1959
Old 10th January 2019, 01:22 AM   #3
perceval is offline perceval  Taiwan
perceval's Avatar
Hard to give any suggestions without a budget and a design in mind.
Once you know what you want to do, and how much you are willing to spend, then I'm sure there will many suggestions.
Old 10th January 2019, 01:27 AM   #4
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Bang for the buck
Bang for the buck definitely needs some context.
Budget, associated kit, expectations, room, room restrictions, taste, WAF…
That said my personal vote for bang for the buck would be Alpair 7.3 (A7.3eN/A7 MAOP). Same voicing at a lower price, Pluvia 7.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 10th January 2019, 01:44 AM   #5
mashaffer is offline mashaffer  United States
I second MA if sensitivity is not crucial.
If you are not a part of the Solution... you are a part of the Precipitate
Old 10th January 2019, 02:31 PM   #6
Well, to narrow it down to my current search -- small woofers (4" or below) suitable for vented boxes, plastic or aluminum cones. No need for full range (as provided by the Mark Audio Alpair 7.3).
Old 10th January 2019, 03:04 PM   #7
perceval's Avatar
Well, considering that you posted in the Full Range section of the forums, I think it's normal you got the suggestions above.
Since you still don't want to share your design goals and budget, I think you might want to move to the Multi-Way forum and try your luck there.
You might get lucky!
Old 10th January 2019, 03:10 PM   #8
Ah, my mistake. I saw "full range" and thought "multi-way". Thanks.
Old 10th January 2019, 10:04 PM   #9
chrisb is offline chrisb
To reinforce both Perceval and mikejennan’s comments, don’t be surprised to see at least a few more endorsements for the general concept of (single) full-range driver systems, and specific Mark Audio models as delivering bang for the buck.
Unless you’ve actually heard a well implemented system with such a driver, I’d counsel against dismissing the category out of hand. Of course, as Dave noted context is very important, so without understanding the application it’d be difficult for anyone to formulate a short list of candidates.
Retired from active DIY
Old 11th January 2019, 01:31 AM   #10
Oh, I'm not dismissing the concept of a full-range driver. It's just that in this case I need to design a low frequency unit to integrate with an existing mid/high system (Xover ~ 300 Hz).
Bang for the buckHide this!Advertise here!
best bang for cap buck rbnjr Multi-Way 8 11th May 2015 06:00 PM
Best bang for the buck PA sub 500 watts? mr. doom PA Systems 1 7th March 2011 03:38 AM
Best Bang For The Buck ! Marquitos323 Subwoofers 8 3rd March 2011 02:58 AM
Biggest Bang for The Buck? Patrick Bateman Subwoofers 41 26th September 2008 01:13 AM
most bang-for-the-buck sub-amp skogs Solid State 12 8th September 2007 10:22 AM
Copyright ©1999-2019 diyAudio
