Best box?
Best box?
Old 7th January 2019, 04:53 PM   #1
LeifB60 is offline LeifB60  Sweden
Default Best box?
I wonder what is the best box for a Fostex 207e ?
Please help me.
Old 7th January 2019, 05:40 PM   #2
Galu is offline Galu  Scotland
I presume you've already searched this site?
Fostex 207E enclosure suggestions
Old 9th January 2019, 05:57 AM   #3
GM is offline GM  United States
GM's Avatar
'Best' is what works 'best' in your room's acoustics with the various genres of music/whatever it will need to reproduce. In general though, this column/tower [MLTL] is probably the most copied: FT-2000
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 9th January 2019, 10:54 AM   #4
Thanks GM.
MLTL. Is the first choice then.
Do you think a TQWT will work to?
Old 9th January 2019, 04:20 PM   #5
GM's Avatar
You're welcome!
Yes, its low Qt 'allows' pretty much any practical taper since adding BSC can include some additional series resistance to raise its effective Qts [Qts'] to 'fill' the larger, normally lower tuned MLTL and even lower tuned, expanding ML-TQWT/ML-horn, but the constant tapered MLTL requires the least internal damping for a given bulk, tuning, hence most acoustically efficient overall, not to mention my main reason for adopting/embracing/endorsing it since 1968, easiest overall to build.
Qts' = Qts + any added series resistance [Rs]: mh-audio.nl - Home
GM
Old 11th January 2019, 10:50 AM   #6
I have read about half Curvy Chang.
Do any now about plans? Were can I find them?
Old 11th January 2019, 05:56 PM   #7
GM's Avatar
Did you search this forum with no luck? Google?
Truly curious as I only had half a clue, but chose to search for them, which took me straight to a lot of dead host site pages as well as the functioning main page, but after that it became a bit of a 'treasure hunt', winding up somewhere I don't recall ever seeing or plans of speaker designs I've never heard of AFAIK. [Dr.] Scott[moose] was even busier than I thought!
GM
Old 11th January 2019, 06:11 PM   #8
To found a box is tricky for Fe207E. BR have I found.
I use the program resp. With that i found TL with smaller and smaller area i get the best results. But I am not sure with the result.
Old 11th January 2019, 11:29 PM   #9
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Best box?
Chang plans are archived… email me for the planset URL.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th January 2019, 12:03 AM   #10
GM's Avatar
So much for me getting an answer............. note the email link doesn't work for me: The Spawn Family of Double Horns
GM
Best box?Hide this!Advertise here!
Copyright ©1999-2019 diyAudio
