Reduce mouth resonance in horn
Old 11th December 2018, 09:12 PM   #11
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Originally Posted by tapestryofsound View Post
I hear what you say, only I have difficulty visualising it. Semantics, and my lack of intelligence, probably
ToS
For example, take this fictitious BLH and let’s assume you have a pesky 175Hz peak, adding a 19in long stub helps to absorb this peak by 3 to maybe 6dB depending on location and stuffing used.
Reduce mouth resonance in horn-d72dd4a7-c5cf-42a7-9cba-9821af6fc172-jpeg
Putting stub entrance near excitation throat helps.
File Type: jpeg D72DD4A7-C5CF-42A7-9CBA-9821AF6FC172.jpeg (730.2 KB, 247 views)
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 11th December 2018, 10:36 PM   #12
Soldermizer is offline Soldermizer  United States
Soldermizer's Avatar
A stub (Helmholtz resonator?) in a horn would be so effective it would remove desired program content at the tuned frequency.
“[G]enes are predicting that sweet taste in the mouth, and orgasm, are going to be ‘good’ in the sense that eating sugar and copulating are likely to be beneficial to gene survival. The possibilities of saccharine and masturbation are not anticipated…” Richard Dawkins, The Selfish Gene
Old 11th December 2018, 10:50 PM   #13
Got Foam?
xrk971's Avatar
That’s why you adjust it so that the attenuation makes it neutral. It can all be simulated in some horn programs, like Akabak.
Old 12th December 2018, 01:35 AM   #14
tapestryofsound is offline tapestryofsound  Scotland
Ah, now I see and understand exactly what you mean! I am very much in favour of what I call 'mechanical eq' through construction - even though I use a (very nice) guitar eq pedal with my present mono horn playback.
Thank you for making a proper drawing for me, it is the kind of thing that sticks and stays for me. I'm going to keep this very much in mind for my next build.
ToS
Old 12th December 2018, 01:45 AM   #15
GM is offline GM  United States
GM's Avatar
FYI/FWIW, part C. Band-stop filters: http://users.cms.caltech.edu/~ps/All.pdf
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 12th December 2018, 02:05 AM   #16
GM's Avatar
Danley Sound Labs' DTS20 tapped horn with dual resonators made from PVC pipe components to smooth out its HF 'out-of-band'/phase response:
GM
Old 12th December 2018, 03:26 AM   #17
GM's Avatar
+1, one of my design 'mantras' is the pioneer's 'acoustical solutions to acoustical problems'.
GM
Old 12th December 2018, 06:10 AM   #18
David McBean is offline David McBean  Australia
Originally Posted by Soldermizer View Post
I like the idea of building McBean's infinite horn
I'm not sure that you would like the response below cutoff very much, though :-).
www.hornresp.net
Old 12th December 2018, 09:53 AM   #19
cowanaudio is offline cowanaudio  Australia
cowanaudio's Avatar
If the horn is going to be infinite, just give it a 10Hz flair rate. There, no subwoofer required. It would actually be smaller than the infinite 100Hz horn too!
Don't Procrastinate....Just Do It!
Old 12th December 2018, 12:04 PM   #20
I was lying in bed last night and it occurred to me: the stub/Helmholtz won't solve our problem! Yes, it would be good to reduce (say) a 1000 Hz peak. But the mouth reflection issue is one of delay (time) of the entire signal leaving the horn. Per Bouska and others, the distortion is a low-passed and multiply time delayed alternately inverted/not inverted delay of the signal.
Reduce mouth resonance in hornHide this!Advertise here!
direct diaphragm connection to reduce resonance caused by AC current interference elac310 Multi-Way 2 11th July 2016 07:02 PM
tubular bass horn mouth termination / decrease in expansion at mouth meko Subwoofers 13 17th February 2014 02:20 AM
Modifying horn flare/cutting a horn's mouth Andy_P Multi-Way 10 5th May 2010 03:25 PM
Horn Mouth Diffraction mefistofelez Multi-Way 11 14th October 2005 01:04 AM
Screen in horn mouth? Stocker Multi-Way 7 9th March 2005 09:39 AM
Copyright ©1999-2019 diyAudio
