Enclosure designing...please help me!!
i am in trouble! help me guys..
the T/I parameter of my woofer driver are-
FS:-59hz
QTS:-0.62
QES:-0.74
VAS:-45.48lt.
i have only 1 cubic foot of enclosure volume.
what should i do? if i am not wrong...closed enclosure is not possible(boomy...not satisfactory) with that volume.
Should i go for vented/ported?
what would be the tuning frequency??:confused:
With 1 cubic foot the only possible solution is a closed enclosure. Stuff the enclosure with glass-wool. With vented enclosure the sound will be more boomy than sealed.
Founder of XSA-Labs
Joined 2012
Sir where r you? the effective cone diameter(membrane?) with outer suspension is 9inch & without suspension is 7.75inch. i don't know about xmax. please help me out.
Measure the diameter of the cone from the midpoint of the surround. Assuming it is a half-roll rubber or foam type, measure from the apex (highest point). Measure this to the nearest mm. Use that diameter and pi x d^2 to get membrane area in cm^2. Typical 10in dia drivers will be about 340cm^2.
It would be helpful to give us the brand and model number of the driver. If you have TS parameters, usually will be given by manufacturer as well.
For a 1.0 cu ft (28.3 liters) sealed box,
Fc = 95, Qc = 1.0.
Here are a couple of other points on the response for 1.0 cu ft.
at F = 67 Hz, dSPL = -3 dB (below sensitivity)
at F = Fc = 95 Hz, dSPL = 0 db (at sensitivitiy)
at F = 125 H, dSPL = + 1.3 dB (peak above sensitivity)
The 1.3 dB peak at 125 Hz may not be objectionable.
If you are able to make a 2.5 cu ft (70 liters) closed enclosure, the response would be considerably better.
Fc = 75.8 Hz, Qc = 0.80
There is no appreciable peak in the response for Qc = .80. The -3 dB point is at 60 Hz.
Vented box does not seem to work well in either case. The peak only becomes more pronounced with the vent tuning options that I tried. There may be vented solutions with enclosures larger than 1 cu ft that give a slight ripple in the response, and maybe acceptable.
Are you sure? with closed/sealed enclosure what would be the sound quality? bass? how much stuffing i need for 1 cubic foot volume? one more thing i want to say, the enclosure volume is 1.64 cubic foot. regards.
Complex for dumb like me :scratch::scratch:
Sadly, this is not a expensive driver.
cheap product...not like eminence or jbl.
the manufacturer is SWETON. there is no model no:D
