Enclosure designing...please help me!!
Old 22nd January 2019, 10:45 AM   #41
nirupambhowmick is offline nirupambhowmick  India
Originally Posted by GM View Post
Actually, there is ; 100 WT woofer [scroll down]: Sweton -Transducers Since 1982 ::Woofer Series - Pro Loudspeakers || Home Loudspeakers
Note that when using Sd, Re, Mmd, BL to calculate specs, they're quite a bit different according to Hornresp, though in power sims are identical when tuned to the lower Fs:
Fs = 45.82 Hz
Qes =0.54
Qms = 5.10
Qts = 0.49
Vas = 53.97 L
If true, with a 0.7 mH @ 1 kHz, this implies an above average quality.
Assuming a reasonable 5 mm Xmax, peak power is limited to its 200 W peak music power when tuned to Fs, so not much low bass, but plenty of mid-bass for 'slam'/'punch' [the original 'low bass' on vinyl, etc..].
GM
Hi ! i have made the cabinet(vented), but it sounds horrible...very low bass, blurred & not satisfactory.
Inner dimensions are 18inch high- 11.75inch width- 10.5inch depth(1.2cuft approx). it has 22inch long 2inch dia port.
Very disappointing result.
i am going to seal it.....
Old 22nd January 2019, 10:48 AM   #42
Originally Posted by xrk971 View Post
My mistake - you have over 1cu ft and as you say, about 1 cu ft after deduction of bracing and driver etc. just go with 3in vent then, but okay around with 5ohm to 6.8ohm resistor an d see what sounds best to your ears. 1mH choke with 20ga copper is not expensive.
You can split into 2 smaller vents - match cross sections area. If not you can adjust length. Play with it and see what sounds good.
Plot just shows whatever name I save file as but not what I actually ran, as it is modified on the fly.
Even ferrite core can work. This one is 0.5ohm DCR and passes 3amps.
5pcs/18mm 6826D 1MH 0.5 Line 3A Iron core Magnetic ring inductors Annular Winding inductors-in Inductors from Home Improvement on Aliexpress.com | Alibaba Group
Here is air core:
Jantzen 1056 1.0mH 20 AWG Air Core Inductor 696554349636 | eBay
Old 22nd January 2019, 10:53 AM   #43
Originally Posted by perceval View Post
f
Why the 1 cubic foot limitation?
Actually it has 1.2cft inner volume.
with vented enclosure the result is very disappointing
Old 28th January 2019, 08:41 PM   #44
Hi everyone! i have made the box sealed. the result is very good & i mean it (at least to me & i am not a truly audiophile guy). Clean sound reproduction with punchy bass! :-) Thousand times better than with vent. Thanks to XRK audio & others.
Old 29th January 2019, 12:17 AM   #45
GM is offline GM  United States
GM's Avatar
I can imagine! You tuned it ~a half octave higher than I recommended, to the point where it was almost a 'one note' boom box, though even with mine, some folks would have added some extra stuffing in the cab to tone it down a bit more.
Regardless, sealed is almost always going to be the best choice overall when the box is acoustically too small for the driver.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 29th January 2019, 12:35 AM   #46
GM's Avatar
Actually, 'punchy' mid bass as the bass is steeply rolled off whereas your vented [shadow trace] had a ~ +6 dB peaking [AKA 'one note'] in the mid bass, then dropping at a much faster rate than sealed.
GM
File Type: png Sweton 100 WT sealed Vs vented in ~1 ft^3.PNG (53.7 KB, 98 views)
Old 1st February 2019, 07:34 AM   #47
GM
Hi...actually i can make amplifiers but had zero
knowledge about speaker enclosure!
this forum is very helpful.
Old 1st February 2019, 09:36 PM   #48
GM's Avatar
I assumed as much, hence the response, though there have been folks that know 'stuff' yet will play dumb to see how much 'we' know and/or hope some 'new' useful tidbit will get posted.
GM
Old 5th February 2019, 06:30 PM   #49
GM
No...i am not. it's nice to meet you. bye friend.
Old 6th February 2019, 07:25 PM   #50
GM's Avatar
Same here, have a better one......
Enclosure designing...please help me!!Hide this!Advertise here!
Need help designing a subwoofer enclosure futuredj Subwoofers 25 23rd December 2015 04:38 PM
when designing a 2 woofer enclosure... slicemaster101 Multi-Way 33 5th April 2012 06:55 AM
Audax HM100CO: Designing an Enclosure Around It Karl71 Multi-Way 7 26th September 2011 07:17 AM
Designing enclosure volumes Syncroniq Multi-Way 4 6th June 2008 12:09 PM
help designing an enclosure felzi Subwoofers 7 5th July 2005 06:20 AM
Copyright ©1999-2019 diyAudio
