Best speaker design for living room
Old 20th October 2018, 05:25 PM   #41
Lingwendil is offline Lingwendil  United States
Now with high-fructose ASSAULT-gluten!
Lingwendil's Avatar
I can recommend a pair too, but I honestly think they aren't enough for that large of a space. Maybe fullsize with a 12" coax? With some .4x or .53x using 3FE25 for roomfill? Augment with a pair of 12-15" subs?
I mean, that's what I would do
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
Old 20th October 2018, 09:18 PM   #42
MITsound is offline MITsound  Canada
MITsound's Avatar
I tested out two per channel 3FE22 Faital Pro , solen split at 6000 Hz, crossed Solen Split to Celestion 1525e, at 1750hz. Very decent sound, with more than enough volume for me, with Class A 10 watt per channel amps, in a room about half your size.
Settled on planar mids and matching tweeters, but I do love those Faitals, with one handling upper mids, and the other handling treble, I think they are more involving than my planars.
Sort of the nice date, versus the fun date.
"Aim above morality. Be not simply good; be good for something." HD Thoreau
Old 20th October 2018, 10:50 PM   #43
kec is offline kec  United States
kec's Avatar
I just built a line array (only one side so far) using 12 3FE25s. I wired it with the power tapering per Mr. Griffin's white paper (attached). I'm really impressed with it so far. I'm using a seperate woofer (DC160) for bass duty and miniDSP (4X10 HD) for the X/O, no additional tweaking done yet. This is in a medium sized room 15' X 30' X 8' ceilings.
MSI E350IS mITX > Foobar > SPDIF > Denon A7100 preamp > Crown XLS1000 > ?
Old 20th October 2018, 11:06 PM   #44
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
I just got a new pair of 0.53x Karlsonators with dual 3FE25-16’s. It has an amazing mid range and excellent top end - surprisingly airy almost like a dome tweeter. It’s a great speaker with a low power amp.
Mini Karlsonator (0.53X) with Dual TC9FD's
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 20th October 2018, 11:53 PM   #45
Bigun is offline Bigun  Canada
Bigun's Avatar
I solved a similar problem some years back, I.e. a sound that fills a room regardless of listening position yet with amazing sound quality. The answer was a single mono speaker, built around a large full range driver with whizzer for excellent dispersion. Search up for my Big’un Audio Nirvana 15”
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Best speaker design for living roomHide this!Advertise here!
recommend a DIY synergy design for my living room? tommus Multi-Way 25 15th April 2018 01:33 AM
Looking for a Tube Kit Amp for my Living room HarryY Tubes / Valves 11 24th October 2017 05:05 AM
5-way active filtered living room set juulmaessen Multi-Way 41 18th October 2017 09:08 PM
Large living room Speaker suggestions gorfeas Multi-Way 15 9th January 2012 08:23 AM
Hello from my living room. Which is in Oregon m00n Introductions 5 10th February 2004 03:31 AM
