Subwoofer active, with open baffle with Fostex Fe206en and 300B amplifier.
Old 13th October 2018, 09:23 PM   #1
santitrucco is offline santitrucco  Argentina
Default Subwoofer active, with open baffle with Fostex Fe206en and 300B amplifier.
Hi friends, I am building an open baffle with Fostex Fe206en and one active subwoofer.. Could be possible to work from 150hz with the Fostex drivers in an open baffle and from 150 to 40hz with the active subwoofer?
Old 14th October 2018, 01:30 AM   #2
Old 14th October 2018, 01:39 AM   #3
ewollowe is offline ewollowe  Australia
I think most here would rather have stereo woofers as you're going to be able to localize the sub at 150hz.
I've been playing around with sub crossover points recently and find I have to set it to 50hz to avoid its contribution becoming too obvious. Even 80hz I could locate it.
Place it centrally and give it a listen, you might find it acceptable?
Irishman downunder
Old 14th October 2018, 01:49 AM   #4
chrisb is offline chrisb
I think the issue with an XO as low as our Irish friend suggests is that the FE206 would be very hamstrung trying to get that low in an OB - that's a driver that really wants a BLH to get much output below the mid hundreds without running into X-max limitations.
Fate - something that people make up to try to explain how things worked out
Old 14th October 2018, 02:38 PM   #5
Chrisb, yes, for this reason I think 150hz maybe would be a good start point. Fe206en have 1.5mm xmax
Old 14th October 2018, 03:11 PM   #6
You've misunderstood? We think the xmas is limited for the crossover point you want in a open baffle. I'm not sure how to be clearer?
But give it a go, you might find at moderate levels it works for you? I've had good results from all kinds of odd set ups.
Irishman downunder
Old 15th October 2018, 03:00 AM   #7
perceval is online now perceval  Taiwan
perceval's Avatar
Depending on the size of the baffle, your FR could start dropping at 300Hz.
Also, freeing the FR from the low end will increase its clarity, meaning lower distorsion. So, a XO between 300 and 500 is best. That means, you'll need a woofer.
Of course, expectations of each and everyone are different, but since we don't have any information on how you will listen, and what, then all these are just speculations on what you need.
Old 15th October 2018, 04:20 AM   #8
ewollowe - yes, I think a fundamental misunderstanding of both the several posts on this thread so far, as well as the general subject might be at play
and if I may be so bold, I think perceval's above post needs to be understood to mean "a woofer per channel"
Old 15th October 2018, 04:41 AM   #9
perceval's Avatar
Thanks for the added precision!
Yes, indeed, I meant a woofer per channel.
Old 15th October 2018, 10:15 AM   #10
KaffiMann is offline KaffiMann  Norway
Fanatic
KaffiMann's Avatar
+1 for stereo bass and xo at 3-500hz.
FC152
Subwoofer active, with open baffle with Fostex Fe206en and 300B amplifier.Hide this!Advertise here!
My Fostex 103's with open Baffle cradeldorf Full Range 11 18th July 2014 02:29 AM
Why my open baffle bass speaker sound like active subwoofer? erez1012 Full Range 8 3rd March 2014 12:47 PM
Open Baffle active Xo/EQ/Amp design Zicdave Multi-Way 0 15th May 2012 10:55 AM
Fostex FE167E Help with open baffle needed jmillerdoc Full Range 4 8th December 2009 04:20 PM
Open Baffle Desktop - Fostex 4 angeloitacare Multi-Way 2 8th June 2009 11:49 AM
Copyright ©1999-2019 diyAudio
