Full range outdoor  BT
Old 28th July 2018, 10:35 PM   #11
jimk04 is offline jimk04  United Kingdom
Originally Posted by xrk971 View Post
Thatís super cheap for a dual PBTL amp. Itís only 100w with 4ohm loads but thatís ok. The parts visually look decent as all are film caps. Looks like a large MKP film cap on the input even. I might order one of these for fun too.
What is PBTL?!😁
Old 30th July 2018, 06:11 AM   #12
Having decided on the 3FE22 8ohm version, I have jotted a few notes down and seem to have written 1.5 litres, 25mm port and a 1mH/6.8R BSC filter.
Do you think the BSC is required for outdoor use.?
And is that 1.5 litres per driver? Using 2 in stereo so im guessing 3litres.
Old 30th July 2018, 06:41 AM   #13
perceval is offline perceval  Taiwan
perceval's Avatar
BSC is a personal taste.
Just build them, and see if you need one.
Then, you just need to adjust the resistor value to tailor to taste.
Old 24th August 2018, 04:36 PM   #14
Connect left and right via speaker wire via external binding posts. This gives it ability to be both powered and unpowered passive speaker. I don’t think it’s an issue to drive the outputs of a TPA3116 output with signal from and external amp if the TPA is turned off.
I think I proved this wrong! I tried to wire it into the back of my MA Radius speakers whilst they were still wired to my Denon AVR. Blew the chip! Even with no audio signal playing.
This refers to a Breeze audio amp I picked up, not the PBTL board I linked to
Old 20th September 2018, 02:54 PM   #15
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Anyone planning on making BT speakers should look at this. Tough to beat with DIY.
Dayton Audio MK402BT Powered Bluetooth 2-Way Bookshelf Speaker Pair with 3.5mm Aux In
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 21st September 2018, 07:10 AM   #16
BrockLanders is offline BrockLanders  Estonia
Aptx is only available for selected Android phones. And is not lossless even if you consider 1411kbps CD quality lossless.
Easiest way to understand different formats is when you compare them in kbps.
Streaming providers:
Apple Music: 256kbps AAC
Spotify: up to 320kbps OGG
Google Play Music All Access: Up to 320kbps MP3
Deezer: 320kbps MP3, 1411kbps FLAC, MQA (3072 kbps)
Tidal: 1411kbps FLAC, 320kbps AAC, 24-bit MQA (3072 kbps)
Amazon Music Unlimited: Undisclosed, presumed 320kbps
Qobuz: 320kbps MP3, 1411kbps FLAC, 24-bit FLAC (3072 kbps)
BT streaming quality:
SBC - The mandatory and default codec for all stereo Bluetooth - 328 kbps
Apple iOS/OSX AAC BT codec has a limit of 250 kbps. Apple uses a bit different technological approach and their AAC 250 kbps sounds similar to SBC 328 kbps.
aptX - 384 kbps
aptX HD - 576 kbps
Sony LDAC (Andorid) - 990 kbps
Someone please correct me if I made a mistake somewhere.
Basically BT streaming is big a mess with different technologies on different platforms. I assume most of us use iPhones for streaming, so my suggestion would be streaming via wifi with this affordable tiny box. Neet(R) - WiFi Wireless Music Receiver - AIRPLAY + DNLA: Amazon.co.uk: Electronics
You can attach this to any BT speaker system, runs on 12v. It uses Wifi-Direct technology which means you don't have to be conneted to Wifi network, phone and box will communicate directly. Then iPhone users can use AirPlay streaming - it is 100% always cd quality 1411 kbps.
Old 21st September 2018, 10:47 AM   #17
Got Foam?
xrk971's Avatar
Thanks for the analysis and recommmendation of a streamer hub. I use Alexa Dot a lot of the times as I have Amazon Prime. It sounds quite decent. The added functionality of all the other features makes its value proposition case substantial. But will look into Airplay streaming.
Old 22nd September 2018, 08:15 AM   #18
Yes thanks for all that. And the link to the Dayton speakers. Look good value.
My wife has iPhone and streaming music to her car with BT is appreciably lower SQ than my Samsung phone.
This speaker build of mine has taken a different direction now but I will update soon.
Old 25th September 2018, 07:02 AM   #19
So as promise my BT outdoor speaker morphed into a stereo pair of small bookshelves, just to cut my teeth in speaker building. Based on an Ikea storage box and Faital Pro 3fe22. Approx 3.5 litre after adding a plywood lining to stiffen. 30mm port of 90mm length tuned to 85hz.
Only got them finished last night so limited listening so far. They are in my living room powered from denon avr and teamed with a rel sub.
Initial impressions are of an amazing soundstage. Way better than my Monitor Audio radius 90.
I shall start a new thread and close this one here.
Old 25th September 2018, 07:03 AM   #20
Sorry for images at 90deg...?!
Full range outdoor  BTHide this!Advertise here!
full range + woofer OR full range + tweeter ? Bigun Full Range 37 25th July 2017 06:17 AM
Anti Sound for an outdoor shooting range Steinmaster170 Everything Else 18 29th January 2016 11:04 AM
Yamaha's JA-5004 non-circular/odd: Most ultimate Full Range / Mid range transducer ? tiefbassuebertr Full Range 2 3rd March 2012 06:59 AM
Frequency range of the human voice & full range center channel speakers jwmbro Multi-Way 31 20th January 2008 03:07 PM
