New Markaudio Drivers
Old 13th November 2019, 07:25 PM   #1161
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
The Jordan has a phase plug, none of the MA do. Dust can get into a driver with a phase plug, but in a normal mounting is not an issue, i’d avoid mounting one castle style.
To get into the gap stuff would need to travel via the inside past where the spider isn't (in the mono-suspension) or thru the ventalation holes above the spider on the voice coil bobbin.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 13th November 2019, 07:31 PM   #1162
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Right; it's a bonded dustcap, no central plug so the whole frontal surface is sealed.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 13th November 2019, 07:37 PM   #1163
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
It was just the lack of spider that concerned me a bit, but no worse than a vented pole piece I suppose for dust ingress.
Old 13th November 2019, 08:46 PM   #1164
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
I've yet to see signs of particle entry into the gap. Mind you, I've never mounted them other than vertical and perhaps that's a consideration for not firing them upward?
EDIT:
Oops: I answered the question considering a phase plug. Maybe the same conclusion though?
Old 13th November 2019, 09:07 PM   #1165
agent.5 is online now agent.5  United States
Does anyone have experiences or suggestions of DIY a pair of Markaudio Dolby Atmos speakers, sitting on top of the main speakers aiming at the ceiling? I am thinking a simple sealed box. Not sure which woofers to use.
Old 14th November 2019, 07:29 PM   #1166
frugal-phile(tm)
planet10's Avatar
The CHN 110 data + a number of Dr Scott’s designs, 3 reflex boxes, an intro to the Woden Festival Series of ML-V and the Pensil.
https://frugal-phile.com/downloads/C...1v1-141119.pdf
dave
Note: there is an earlier version that you may see with copies of Scott’s working sketches.
Old 14th November 2019, 07:30 PM   #1167
frugal-phile(tm)
planet10's Avatar
Chris is using P7 in Plu-Kens, you idea seems feasible.
dave
Old 29th November 2019, 08:50 PM   #1168
Jason Shep is offline Jason Shep  United Kingdom
Jason Shep's Avatar
Hi all, what speaker cable do you guys recommend using with MarkAudio?
I have just switched out my MacMini for a dedicated music server, Innuos Zenmini & the improvement in sound quality has prompted me to investigate other areas of my system to see if I can make further improvements, I’m currently using VanDamme 1.5mm speaker cable.
Old 29th November 2019, 08:58 PM   #1169
Scottmoose's Avatar
Depends who you ask and what you're trying to do. From my POV, assuming you don't want the wire to provide any EQ, then shotgun format wire, close-spacing, of sufficient gauge for the loop-length to ensure voltage drop is no more than about 0.1.
Old 29th November 2019, 09:35 PM   #1170
frugal-phile(tm)
planet10's Avatar
Which Mark Audio? What amp?
dave
New Markaudio DriversHide this!Advertise here!
Zigmahornet with Markaudio drivers? StevenZ Full Range 13 26th May 2011 06:09 PM
FS: pair of MarkAudio CHR-70 drivers albireo13 Swap Meet 5 30th November 2010 09:07 PM
Copyright ©1999-2019 diyAudio
