Visaton B80/100 experience So?
Old 30th April 2018, 01:47 PM   #11
peterbrorsson is offline peterbrorsson  Sweden
@s4m
I am buying both Klang+Ton and HH and have no problem reading German. Small is desirable today so no wonder he chose to do tiny boxes. K+T have more wonky designs in my opinion�� Anyway, I have listened to the B80 before sending to XK's test mention before in this test, it's a nice driver! B100 I have no experience with...
Cheers��
Old 1st May 2018, 03:44 PM   #12
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Originally Posted by peterbrorsson View Post
@s4m
Cheers��
Yes, I should have mentioned that Peterbrorsson (Thank you!!!) was very kind to donate the B80's the cause of test and compare with other drivers. It really is a fine sounding driver, up there with the best of the best full range drivers.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 1st May 2018, 04:23 PM   #13
No problems xkr, you have paid back with facts unlike most on forums. Right now I'm in direct contact with Faital Pro. Maybe I can make a fair deal buying a bunch of drivers for a line array
Old 1st May 2018, 05:32 PM   #14
Got Foam?
xrk971's Avatar
A line array with 3FE22 16ohms might be very interesting. The 16ohms allows different wiring schemes and may simplify implementation. It has a very natural and smooth response and is 91dB sensitive. Many people are making line arrays with the less expensive ferrite magnet 3FE25 which is also very good but I seem to recall that 3FE22 sounds smoother.
Old 2nd May 2018, 06:19 PM   #15
Yes, 3fe22 16 is considered. Even 4fe32 could be in question as I can listen at 6m distance... However, I will move to another country soon, room unknown so far...
Sorry for OT��
Old 2nd May 2018, 08:36 PM   #16
luigi is offline luigi  New Zealand
Originally Posted by S4m View Post
@Xrk Mr Timmermanns of HobbyHifi creates strange enclosures and needs complex XOs to compensate the design faults. His maingoal is to make it different than anyone else but his designs are working... I don't like his stuff but its one of the last speaker diy papers out there and the measurements of new speakers are always intereting
The Visaton 80 and 100 are both not bad but i think for the price you can go with better fullrange drivers.
Which begs the question: exactly what full range drivers are you referring to?
Old 19th July 2019, 01:59 AM   #17
SONDEKNZ is offline SONDEKNZ  New Zealand
SONDEKNZ's Avatar
Default VISATON B-100 / B-80 Experience Anyone?
BUMP!
Any update on this thread, from anyone?
I'm trying to compare the VISATON B-100 with the FOSTEX FE107E - for FULL RANGE (Single-driver, No crossover) use in a small Base Reflex Cabinet.
(Think BLUMENSTEIN ORCA...)
Thoughts or experiences, anyone?
Old 19th July 2019, 02:07 AM   #18
I have FF125wk which some seem to find a bit forward compared with B100.
I too found it like that too, until I messed around with how I mounted it. Instead of flush mounting I found a piece of PVC tube and mounted it proud of the baffle by a couple of inches.
For some reason, this seems to improve soundstaging and imaging. Not sure that it should, but to my ears it does; things are simply easier to locate in space, better defined. And the Fostex no longer seems to have that slightly shrill aspect to it.
A really good driver, a bit easier to drive than the B100 too, or perhaps it is just a bit louder because it is a bigger driver.
Old 19th July 2019, 02:12 AM   #19
SONDEKNZ's Avatar
Default Interesting...
Thanks for the intel, Luigi.
I run the stock FOSTEX FE107E in my ORCAS, but need to replace the drivers.
For smaller rooms like we have in NZ, they are fabulous little speakers - I have to say.
I thought a bit of discovery and (perhaps) experimentation was in order - hence my interest in alternative full-range drivers.
The VISTON B-100 seems to be the right size for the cabinet and has similar specs, but as we all know, specs only tell half the story...
Old 19th July 2019, 02:20 AM   #20
Hi Tony
The B100s work really nicely in my Frugel horns, as do the Fostex. The bass isn't huge with either, but I have a pair of 10-inch woofers in their own enclosures for the bottom end.
I had kind of given up on the FF125s until mounting them proud of the baffle by a couple of inches. Seemed to change their presentation entirely. I have them in something else now, but with the same effect when mounting them "outboard". Course the look makes them no longer appear like furniture, more like alien items, but I just dont give a fig about that.
Visaton B80/100 experience So?Hide this!Advertise here!
yamaha ax-892 and visaton experience v20 primoz1111 Multi-Way 8 11th January 2016 08:42 AM
Visaton B200 dipole experience? tubesguy Full Range 26 23rd May 2012 12:25 AM
Experience with Visaton louspeakers? Andy9485 Multi-Way 6 24th November 2006 06:25 PM
"Visaton - is it worth?" or... "Share your Visaton experience" mr_push_pull Multi-Way 10 7th August 2004 06:18 PM
Visaton drivers .... any experience? alvaius Multi-Way 2 25th September 2002 07:16 PM
Copyright ©1999-2019 diyAudio
