Qtc must be greater than driver's Qts.
Old 19th April 2018, 09:35 PM   #11
SubSoniks is offline SubSoniks  Wales
Originally Posted by IG81 View Post
A driver with Qts=0.8 will indeed never reach Qtc=0.707 in a standard sealed enclosure. A driver's free-air Fs and Qts can only be raised in a sealed enclosure, now convolved into Fc and Qtc.
There may be a special case, correct me if I'm wrong, where a driver with lots of dense stuffing right behind it will have its Qms lowered, by extension lowering Qts below its free-air value, but putting this in a sealed box will still only raise it from there, although Qtc could be lower than free-air Qts. Whether this can be used to good effect is another matter.
Yes
Old 20th April 2018, 05:47 PM   #12
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Originally Posted by CharlieLaub View Post
I reiterate that "a Lower Qt" (your words) is NOT via reduction of Qts.
You're misreading. GM was referring to acoustic effects & OA system Q, hence noting 'technically Qtp' WRT a very heavily damped pipe.
Also, much of what you state above is not correct.
Which parts, when you read it as intended, rather than assuming it refers to the driver's innate EM damping?
Anyway, back OT for the OP, what GM essentially meant was that if you've a high Q driver, then that is the minimum system Q you can obtain except in very specific circumstances which in most cases are 'you can't realistically go there' short of a Linkwitz transform or equivalent LF EQ, which are more easily achieved, but not always possible.
Note that a higher Q driver isn't necessarily 'rubbish' -it may be very good for the purposes it was inteded for. It does give you far fewer options though.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 20th April 2018, 07:51 PM   #13
MattSug is offline MattSug  United Kingdom
Thanks for clearing that up, I'm looking drivers with QTS of around 0.5 now!
Qtc must be greater than driver's Qts.Hide this!Advertise here!
Multi driver benefits? Greater octave range? halibutman Multi-Way 3 25th August 2015 02:38 PM
Substituting 8'' woofer with greater Fs andreaemme Multi-Way 30 16th February 2015 01:43 PM
ANY AMPLIFIER WITH SLEW RATE GREATER THAN 50V/žs? fotios Solid State 36 30th July 2008 11:46 AM
Need 600Watts Or Greater clovi_kate Solid State 8 17th February 2008 08:01 PM
Soundcard greater than 24-bit korneluk PC Based 2 14th December 2007 06:47 PM
Copyright ©1999-2019 diyAudio
