Dallas II Build
Hi Collin,
I used felt cover (8mm, very dense wool) only at the back of the speaker (you can see red lines on the picture).
3 empty spaces are filled with sand (bottom one and 2 around the driver).
For top 2 spaces I used foam (the one you use when mounting windows).
Foam was compromise to save some wight. One speaker has 65 kg.
Speaker is made of 18mm Birch Ply.
Internal wiring is made using silver rectangular + platinum wire around.
I'm very content how they sound.
Good luck and enjoy while you're working on them as much as you will enjoy listening.
Ok, so answer is a).
In my case damping on the left and right side are 2 separate pieces of wool and may be easier to remove than the rest.
What kind of sound change may I except if I try this.
Now when everything is closed it's not easy to play with damping and may create more problems than benefits.
I've cut all my plywood according to this plan (for 18mm sheet), but when trying to draw the layout on one of the side pieces I found that nothing quite fitted exactly where it should. Eventually it dawned on me to check the thickness of the sheet and it comes up as 18.8-19mm, I suppose 2 sheets, different thicknesses.
Realistically what are my options from here? To resize everything I'd more or less need to start again? At a minimum it must need different sides, top base and back pieces? I'm not sure that I have the expertise to rework the drawings.
I have a woodworking workshop nearby, who have been helping me with the build so far. They have a big belt sander that could sand everything down to 18mm but it's an extremely manual process, sanding a bit, checking, sand again - and difficult to get consistency on the longer pieces. But actually may not be as expensive and time-consuming as starting again.
Grateful for practical advice.
I've put some felt in the chamber behind the driver and some thin felt from the old kind of anti-slide material from ikea in some more parts. See the pictures. It's glued with floor glue that's a bit dampening in itself. I use 206-NV with correktion circuits and replaceable resistors. That's also in some pic. But haven't yet measured them, maybe I will when i get the gear for that. I tried out the dampening with the sides only screw-mounted. And then glued them before paint-spraying.
Reactions: 1 user
You might consider
You might consider making up for imperfections using Bondo auto putty. You would want to paint or veneer the horn when done for a nice appearance.
