Hello Dave,
May I use same enclosures for the rs100-4 units?
https://www.parts-express.com/pedocs/specs/295-378-dayton-audio-rs100-4-spec-sheet-revised.pdf
Thank you for the design.
I'm looking to build this for a small height effects speaker.
Do you think that this would work if we kept the dimensions of the front baffle and total volume, but angled it facing down?
The slot port would be relocated to the bottom. Would the same slot shelf length be sufficient? Does the height of the front slot port count as part of the front baffle dimensions?
| |________/
| |________/
I've built this enclosure twice as a stereo pair (first enclosure build) for a squeezebox player, replacing a bose soundtouch 10. Got sick of the updates and them wanting my location for pairing.
Sounds very good, could do with a touch more bass however it's going in a shed workshop so its boomy enough. Hifiberry amp2, raspberry pi 3 with max2play OS and a good quality 24v power supply.
Thanks for the plans Dave
Danny
Danny
Hello,
I order 2 RS100 to build BT speaker.
Can you give me some advice about design for the box ?
I can do something behind 5 to 20 liter...
Thank you
it is OK speaker in Tabaq MLTL, which is ~10L of internal volume. There will be some bass.
I built it in ~95% similar dimensions box like original Tabax and it sounds better than I expected. The only negative is the driver metal cone specifics, but as you already have the drivers it does not matter...
That can be solved with a tweeter or better a 3 way. The only negative is the driver metal cone specifics
Don't tell me that this is the fullrange Forum because I can tell you that there are 3 threads of multiway hidden behind in that category, not counting the Waw and ' tweeter aided'.
1/2 " tweeter ...maybe a bat-whatever
...no, I will not tell you...
IMHO, if there are intentions to use this driver not as single one, then there are better/cheaper alternatives. Besides, there are people who do not mind or like the metallic sound
Those sound like my words.
In the miniOnkens a slot is used as a vent. In most cases given the available length and trying to stay with standard material thicknesses, the vent is too large, so a vent spacer, a solid block of wood, is placed in the vent to decrease its cross-section. This spacer runs from the front of th ebox all th eway to the back of the box.
CGRs and CFSs typically have 0 or 1 vent spacers, full pn miniOnlens 2 or more.
dave
dave
HI Dave,Wool felf?
Jeez, that one is a surprise… done a week before i almost died, guess that could be why it has disappeard from my brain :^)
The metric can be rounded off, it was obviously a quicky.
Have you built it? How does it sound?
dave
No, haven't built it, I just drew up a cut list and off to HW to get some 12mm marine ply, best I can source locally and "only" $41 for a 1220 x 610 sheet.
Ill update once completed.
Cheers
Nik
- Full Range
- Dayton rs100-8 box size help!
