Even BIGGER than Bigger, Badder BIB...
Old 12th October 2018, 03:53 AM   #61
GM is offline GM  United States
GM's Avatar
Originally Posted by freddi View Post
although not simmed correctly*, it looks like a BIGBIB with 2220 would do 100dB- 102dB@30Hz 1 Pi 2.83v w. ~440 liter internal airspace,
assuming the older alnico "A" is close to "H" in spec. (* - used a 4.25M long positive flare T-line with 0.41 offset for that guesstimate)
​Sounds about right, my [parabolic] BIB sim is ~890 L/4.65 m long and averages ~108 dB/30 Hz/m/1pi/2.83 V, though again it's probably going to be lower due to HR being a bit optimistic unless it's one heck of a well sealed, massive/rigidly constructed, space.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 12th October 2018, 10:01 AM   #62
freddi is offline freddi  United States
freddi's Avatar
tried another but don't have a grasp of how to do it
this time I set the horn area at 0.41*path at Sd (does that make any sense??) - then just adjusted things so the schematic looked what assume is about the right shape to finish the expansion
I feel like I've been to the Pa Kettle school of mathematics and flunked
tell me how to do these BIB things
Old 12th October 2018, 03:09 PM   #63
GM's Avatar
Instructions:
The BIB default alignment is Fs/2, so input Fs, Vas, Qts' and it auto calculates everything you need to input it into HR/whatever.
The basic math is: Vb = 20*Vas*Qts'^1.25
Qts' = Qts + any added series resistance [Rs]: mh-audio.nl - Home
If it's too short or too long, i.e. too far from the ceiling or too close, then change 'Fs' until you get the desired folded height.
For really high Fs drivers or just want a smaller floor loaded model, just change 'Fs' to suit.
If it's sheer size/'footprint' is too big for the intended app, then change Vas for relatively minor adjustments and/or Qts' for major ones, though may not adequately protect the driver enough in high power apps.
L*0.217 is the original/standard driver offset with L*0.41 being MJK's alternate when a flatter overall response is desired, though may not adequately protect the driver enough in high power apps.
For compression loaded, i.e. very close to the floor or ceiling, then one of these ML-horn/ML-TQWT driver offsets may be better overall, though again, the further down the less the driver protection at higher power: L*0.349, 0.424, 0.50 - 0.60
GM
Old 12th October 2018, 11:39 PM   #64
freddi's Avatar
is that QTS' ^1.25 "separate"? I got a huge figure (like 35 cubic feet) with QTS'= 0.241 (rg = 2ohm) and 2220A's Vas of 297.3 liters
Old 13th October 2018, 12:43 AM   #65
GM's Avatar
No, ~35.46 ft^3 is correct. Conical pipe horns mostly load by air mass volume alone, so air not being very heavy.............
GM
Old 13th October 2018, 01:05 AM   #66
freddi's Avatar
hey GM - I certainly appreciate the info and clarification - add some wood to 35.46CF and that's a whopper. 4 ohm Rg would raise 2220A QTS' to 0.3.
A K alignment formula might be handy too - think they're only relegated to certain size limits.
Old 13th October 2018, 02:11 AM   #67
GM's Avatar
You're welcome! High time I consolidated all the info I posted piecemeal as required. Apparently these cab alignments aren't ancient history just yet.
Judging by the HR sim, one could probably do well enough with ~35*0.707 = ~25 ft^3, just will have several dB less power handling down really low where the room may already be boosting too much anyway. The extra acoustic loading I factored in was more for 'FR' drivers where even Fs/2 with next to nothing power handling was going to normally be > 20 Hz.
GM
Even BIGGER than Bigger, Badder BIB...Hide this!Advertise here!
BBBIB Bigger Badder BIB Speaker Variac Multi-Way 285 16th September 2012 07:34 PM
