Need advice, should I jump into Lowther league?
View Poll Results: question : as of topic
Yes : it will bring you a new nirvana 5 18.52%
No : it's a waste of time and money 22 81.48%
Voters: 27. You may not vote on this poll
Old 29th July 2019, 09:10 PM   #71
pelanj is offline pelanj  Czech Republic
There is not much bass to speak of. For some things it is not a big deal, but for true enjoyment, some sort of bass unit is needed. I temporarily use 15 inch OB woofer for LF augmentation, for the final system I plan to use multiple sub setup since they can be concealed somehow in the room. I find the low end of any FR speaker not satisfactory, but Fane 12" FR comes really close to acceptable in a large box.
Old 20th August 2019, 02:53 AM   #72
Retsel is offline Retsel  United States
Default About Lowthers
I initially "adopted" a set of Lowther DX2 in Hedlund Horns, and subsequently traded up from DX2s to DX4s. The DX4s were excellent in Hedlund Horns.
I then purchased the plans for Basszilla speakers and put the DX4s into Basszilla open baffle speakers. The Basszilla speakers delivered an improvement in transparency over the backhorns, but with cost of less bass. Lowthers in open baffles are outstanding in sonic quality.
I was able to use the Lowthers in a larger room, so I moved to front waveguides (conical horns) for Lowthers which requires other speakers below 500 hz. The efficiency of the Lowthers increased from 95 or 96 db/watt in open baffles to about 101 db/watt in the front waveguides. The quality of sound is outstanding. An audiophile friend of mine used Lowthers in front horns, and a shootout between Lowthers in Tractrix horns and Bruce Edger midrange horns using compression drivers, and most of those there preferred the Lowthers.
To successfully use Lowthers, one must be willing to tweak them, adjust their crossovers and play with different diffusers - they are not plug and play. Also, it is important to know the different Lowther types for the different speakers that could be matched with them. Without these considerations and adjustments, I can understand why people have such negative opinions about them. One can debate whether Lowthers are worth their high purchase price, but if implemented well, it is difficult to argue that there is not something special about their sound.
Retsel
Old 21st August 2019, 02:24 PM   #73
Colin is offline Colin  United Kingdom
Originally Posted by GDO View Post
Ha! Ask the guys at Lowther how the Eikonas sound, after all the first batches of Eikona came from their factory.
I guess they became so jalous with the sound that Ted Jordan, despite his personal interest in "proudly build in UK", had finally to resign again to fall into danish hands...
Sorry to jump into the thread, but to dispel an often-repeated myth:
Ted announced that he was working with Lowther at one point but it didn't come to anything. The Eikona 1 was not made by Lowther, but was made in the UK. The inability of the company concerned to ramp up production to meet demand led to the move to produce the Eikona 2 with Scan-Speak. It was not the cheapest option but definitely the highest quality.
EJ Jordan Designs
www.ejjordan.co.uk
Old 21st August 2019, 02:26 PM   #74
Originally Posted by planet10 View Post
Yes. 1st gen built by Lowther.
dave
See my comment above.
EJ Jordan Designs
www.ejjordan.co.uk
Old 21st August 2019, 02:34 PM   #75
On topic:
I've heard a pair of Lowthers used in one of their reflector enclosures (a corner horn of some sort (possibly the Dual Position Acousta from the 1960s) and thought it sounded very good. it was being used in a Russ Andrews dem to show how good older equipment could sound, given appropriate matching equipment.
EJ Jordan Designs
www.ejjordan.co.uk
Need advice, should I jump into Lowther league?Hide this!Advertise here!
League For High Efficiency Loudspeakers adason The Lounge 197 6th January 2016 05:10 AM
Electrolytics just took a mean jump! Geek Parts 5 23rd November 2009 11:02 PM
Advice on SE DHT for Lowther Fidelio DX2 Rudolfs1972 Tubes / Valves 5 31st July 2007 10:18 PM
Help on pre-design decision (premier league) Alves Multi-Way 0 21st November 2006 06:13 PM
Copyright ©1999-2019 diyAudio
