Another FHXL Build
Another FHXL Build
Old 21st January 2018, 11:33 PM   #111
Eric is offline Eric  United States
Eric's Avatar
Another FHXL Build
Appreciate the advice, as always, Dave! This is a relatively easy mod to make. I'm looking forward to a matched trio for the front array.
My DIY Basement Theater, Aleph-X Amps, LDR based BA-3 pre, Pearl II, highly modded Technics SL-1200, F4, M2, Aleph-J, MoFo, a40, several ACAs, FHXL, Tang Band 1772 bass-reflex
Old 28th January 2018, 12:35 AM   #112
Eric's Avatar
Another FHXL Build
Five coats of tung oil finish later, here is my finished center. Turns out that one 4x8 sheet of veneer is enough to cover all three speakers in the front array, with just a bit left over for another small project.
I didn't spend the time to break this driver in like I did with my left and right channels, so I'll reserve any comments on sound until after another few weeks go by. For now, I've left the more dense felt in place until I can locate something that is softer. I also want to make some measurements before I go playing around with things...
Patience, patience...
Edit: Hmmm... looks like I have some reflection across the top of the speaker from something else in the room. The color is more even than it appear in the images.
Old 28th January 2018, 12:39 AM   #113
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Another FHXL Build
Very nice… can you get a soldering iron in if you need to change the wires?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 28th January 2018, 12:52 AM   #114
Eric's Avatar
Another FHXL Build
Not sure if I'll have enough room to work with a soldering iron, but I'm sure I can get a pair of pliers in to loosen the nuts on the back of the binding post. Bottom line: yep, it's doable but will probably take a little while.
Old 28th January 2018, 12:54 AM   #115
frugal-phile(tm)
planet10's Avatar
Another FHXL Build
Why we recommend terminals that come out from the outside. A cup or a homemade plate. We also like post swith less metal in them.
dave
Old 28th January 2018, 01:05 AM   #116
Eric's Avatar
Another FHXL Build
Perhaps I haven't spent the time to look for a nice terminal cup, but ones I've used in the past have left me disappointed that I carved a big hole in my speakers. Thus, I switched to these and just drill a 1/8" hole. So far, they haven't presented a problem...
Old 28th January 2018, 01:13 AM   #117
frugal-phile(tm)
planet10's Avatar
Another FHXL Build
We went hunting for and use the smallest terminal cup we could find… a 2” hole. If you don’t need the requirement that the posts are recessed (to minimize them being broken off) PE has these simple ones. Parts Express Gold Plated Banana 5-Way Speaker Wire Binding Post Terminal
dave
Old 28th January 2018, 06:59 AM   #118
zman01 is offline zman01  Bangladesh
Another FHXL Build
Nice work Eric, the center speaker looks beautiful and a good match to your FH-XL fronts.
Old 28th January 2018, 04:42 PM   #119
Eric's Avatar
Another FHXL Build
I like that speaker input plate, Dave. Thanks for the link!
Zia: Thanks - it is a nice match. The original bubinga wood that I used for the left & right channels was 48-49" long, so the baffle for the center is the bottom that was cut from the left & right baffles, but-joined side by side as book-match, and then laminated to 3/4" bb ply. They sure look nice as three matching speakers, but the center stands out visually a bit more now as the previous speaker was black grill cloth across the entire front. My wife says, "Boy, that one sure stands out more than the last one..."
These three as the LCR array match one another in tonality much better than my previous Atlantic Tech LCR array. The previous ones were THX certified D'Appolito designs and the center always sounded just a bit funny to me (a bit too much lower mid range - so it sounds slightly bloated). The Alpair drivers are clearly more "open" (for lack of a better word) and make the sound appear to be originating somewhere in the middle of the room rather than directly from the boxes. Exchanging the center speaker especially is quite a stark difference, but it's also not broken in yet...
Another FHXL BuildHide this!Advertise here!
Adapt Polk Audio R20 for Classix II build or build box? unpredictableape Multi-Way 3 3rd April 2017 07:25 AM
LJM MX50-SE - Build Log Gallery & My Build Progress dakku Solid State 3 28th October 2016 08:49 AM
Pensil 10.3 vs FHxl sajgre Planet 10 hifi 13 7th May 2016 08:37 PM
question:How to build How to build music player with tda1543 use rapspberry pi B+? gary095315 Digital Source 1 30th December 2015 07:35 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Copyright ©1999-2019 diyAudio
