SAL Full Range Drivers
Old 16th April 2018, 09:04 PM   #321
j.michael droke is offline j.michael droke  United States
Default Moncacor SP382-8A, T/S
Hi there h: Monacor SP382-8A, Great choice for OB with T/S: Fs=25, Qts=0.75, SPL=94db, PWR=150w/300w program, BL=10.87. Thanks the reply and more information on the EQ required at 30hz and bass response observation. ...regards, Michael
Old 14th December 2018, 07:07 PM   #322
hltf is offline hltf
Hi, does anyone know when the SAL 08C08 drivers will become available here in the US again? Thanks
Old 29th December 2018, 10:04 AM   #323
laverda is offline laverda  United Kingdom
You could try an email to Frank, anetteogfrank@gmail.com and ask.
And theres news...spoke to Frank some time ago and he's been busy... and the original SAL driver is still available I believe.
This new driver is designed to have a better dispersion at high frequency in order to reduce beaming, and the breakup is reduced to buy limiting the high frequency energy to the main cone. The new driver uses paper cone to increase the internal damping and a coated aluminums dome for a better response at high frequency.
The wizzer is also gone, this is a must for some people?
I am now using tree cones, so it is basic a tree way speaker using a mechanic cross over. The main cone is running up the about 300Hz, the second smaller cone is running from 300 Hz to about 6 KHz, a coated aluminum. dome is taking over from 6 KHz and up. A thin pice of foam is mounted directly on the aluminums dome. By accident I found the it flattens the respond at high frequency.
Every Day In Every Way I Make It Pay
Old 29th December 2018, 06:15 PM   #324
Can a moderator delete my post No 323 ASAP.
I am unable to do so.
For commercial reasons Frank needs this info to be removed.
May I apologies Frank and to those who had an interest.
Old 29th December 2018, 07:22 PM   #325
BJager is offline BJager  United States
Default Pure Audio Project Drivers
If anyone has interest in the Pure Audio Project OB-A15Neo drivers, I have two sets of (4) available.
One set is listed here:
Set of (4) Pure Audio Project OB-A15 Neo Woofers (new in box!))
The other set is also brand new but I opened the box of one driver to take measurements.
SAL Full Range DriversHide this!Advertise here!
Ohm drivers - can we use full range drivers instead? Godzilla Full Range 2 10th April 2016 01:15 AM
Korean Sonodyne S-654 Full-Range/Wide-Range Drivers thetubeguy1954 Full Range 6 18th January 2011 10:42 PM
I know there are more full range drivers . . . what about . . . Kensai Full Range 21 19th December 2005 04:50 PM
Full range drivers. tade Full Range 5 2nd March 2005 02:59 PM
Full Range Drivers Mohan Varkey Introductions 11 3rd February 2002 10:27 AM
Copyright ©1999-2019 diyAudio
