Full Range TC9 Line Array CNC Cabinet
Full Range TC9 Line Array CNC Cabinet Please consider donating to help us continue to serve you.
Old 18th October 2019, 10:06 AM   #1001
wesayso is offline wesayso  Netherlands
wesayso's Avatar
It looks beautiful!
Use Science to design your speakers and they will sound like a piece of Art...
Old 18th October 2019, 10:09 AM   #1002
fluid is offline fluid  Australia
Originally Posted by wesayso View Post
It looks beautiful!
Thanks! An ugly mess next to the array just wouldn't cut it and I don't have a handy curtain to hide them behind
Old 18th October 2019, 10:26 AM   #1003
Halair is offline Halair  Norway
Looks very slick fluid - I am a little late to the game but wanted to mention that you will increase the absorption by keeping the sides open.
If waves are allowed to enter from the sides you effectively increase surface area used for absorption.
Old 18th October 2019, 10:44 AM   #1004
wesayso's Avatar
For me it worked quite well to have the array closer to that damping panel, as it took out first side wall reflections as seen from the listening position. I'm guessing that side wall reflection would hit in front of the panel as it stands right now (as seen if you put a mirror there from the listening spot). I'm guessing this was just a preliminary picture to show off though?
Old 18th October 2019, 12:04 PM   #1005
I considered doing that but decided against it, I wasn't sure I really needed more absorption. I could still do it on all the others but it's quite a lot more work, hmmm
The reflection is on the far left of the last picture, the positioning is not fixed yet but I did plan to put the larger width panels across the corners as shown to be bass traps. The original plan was to have another panel to the left for that reflection. It may work better to have the panels behind the arrays rather than across the corners to try and reduce the 140Hz null, time will tell as I will test both. But you are right it was a good position to show the scale compared to the array
I could always build more panels but then I really would be in a LEDE room
Old 18th October 2019, 01:27 PM   #1006
chrisb is offline chrisb
Nicely done.
How stable do you find that Bosch sliding compound saw on the folding stand shown?
Oh, and your shop is far too clean
Technology honors no Hippocratic oath
Old 18th October 2019, 08:56 PM   #1007
Originally Posted by chrisb View Post
Nicely done.
Thanks, the stand is good but not quite as stable as on a bench, just needs a bit more care to keep things in line when doing sliding cuts. The saw throws a fair bit of dust even when hooked up to a vacuum so I tried the stand to make it easier to clean up, works well so far.
Ha Ha it didn't look quite so good a few weeks ago, I had to clean it up to be able to do some more work
Old 20th October 2019, 11:55 AM   #1008
Next one underway, I decided to put some holes in the side to try the idea of increasing absorption.
Then I remembered why I decided not to before
Full Range TC9 Line Array CNC Cabinet-img20191020113100-jpg
Ready for glue up
Full Range TC9 Line Array CNC Cabinet-img20191020122011-jpg
Old 20th October 2019, 12:30 PM   #1009
nc535 is offline nc535
Dizzy from routing so many holes?
At least it reduces weight
My Synergy Corner Horns and Bass Bins
http://www.diyaudio.com/forums/multi...bass-bins.html
Old 20th October 2019, 12:33 PM   #1010
I used the TCT holesaw I bought for when I planned to make the array baffle by hand, so no routing.
Definitely lighter I just hope not too wobbly when upright.
Full Range TC9 Line Array CNC CabinetHide this!Advertise here!
Full range line array inrank Full Range 43 16th November 2017 08:25 AM
Full range line array in a tube carpenter Full Range 44 7th January 2014 03:19 PM
Omni full range line array??? Melo theory Full Range 42 25th November 2012 06:44 AM
Full-range line array? mazeroth Full Range 20 1st November 2004 04:47 PM
line array with full range drivers? leadbelly Multi-Way 9 25th January 2003 05:48 PM
Copyright ©1999-2019 diyAudio
