Full Range TC9 Line Array CNC Cabinet
Full Range TC9 Line Array CNC Cabinet Please consider donating to help us continue to serve you.
Old 28th September 2019, 10:43 AM   #991
wesayso is online now wesayso  Netherlands
wesayso's Avatar
This is a RePhase exercise right? Not a real null in the mains, just a virtual one done by EQ, right?
Use Science to design your speakers and they will sound like a piece of Art...
Old 28th September 2019, 12:33 PM   #992
BYRTT is offline BYRTT  Denmark
BYRTT's Avatar
Not shure but could imagine phase of that dip maybe can be a little wild, what i mean is its not pure linear phase and not pure minimum phase but a mix of both, guess a chance to repair that then into REW you need to divide a carefull alligned measured line array IR with textbook target of a carefull alligned target curve IR, to ignore HF stopband from measured IR then filter the two IR before the divide command for example 1/1 at 125Hz and export that as frd file, then over in Rephase use whatever mix of minimum phase and linear phase filters it takes to get that hump flat as pancake in both the amplitude and phase domain, below should be some pointers
Full Range TC9 Line Array CNC Cabinet-1060-png
Old 28th September 2019, 12:56 PM   #993
fluid is offline fluid  Australia
No the null is real, it appears in the averaged measurement and DRC does not try and correct it.
These images show it, 6 cycle FDW to clean up the phase and unwrapped to see the cliff more clearly. The exercise part is combing the real corrected measurement with pure impulses to represent a perfect sub.
Full Range TC9 Line Array CNC Cabinet-average-eq-jpg
Full Range TC9 Line Array CNC Cabinet-flat-test-unwrapped-phase-jpg
I'll have to read that one a few times to understand it I don't think it can be corrected electrically, but needs a combination of absorption and mitigating with the sub channel if possible. I have had no success with dividing impulses before, it always sounds wrong somehow.
Old 6th October 2019, 11:23 AM   #994
Some progress has been made in the physical world
Pile of Glass fibre batts
Full Range TC9 Line Array CNC Cabinet-img20190906160416-jpg
Pile of MDF
Full Range TC9 Line Array CNC Cabinet-img20190906160433-jpg
MDF cut for sub cabinets and absorber frames
Full Range TC9 Line Array CNC Cabinet-img20191006173818-jpg
Full Range TC9 Line Array CNC Cabinet-img20191006173830-jpg
Old 6th October 2019, 02:33 PM   #995
wesayso's Avatar
Big plans!
Old 6th October 2019, 03:58 PM   #996
nc535 is offline nc535
plans for big subs?
My Synergy Corner Horns and Bass Bins
http://www.diyaudio.com/forums/multi...bass-bins.html
Old 6th October 2019, 10:08 PM   #997
Big plans!
I should end with 3 panels 560 x 2260 x 180 (whd) and 5 panels 430 x 2260 x 150
That's what I got out of two bags of glass fibre and three sheets of MDF
Originally Posted by nc535 View Post
plans for big subs?
Roughly 500 x 500 boxes for the 15" drivers, reasonable compromise between size and efficiency
Old 6th October 2019, 10:16 PM   #998
DonVK is offline DonVK  Canada
DonVK's Avatar
Are those panels for your null? or general room treatment?
Old 7th October 2019, 01:05 AM   #999
The original idea was for corner traps and first reflection control. Having measured, the ETC shows less early reflections than I thought but a few bass nulls, so I will try to see if I can reduce the front wall null enough to be dealt with by other means.
Old 18th October 2019, 06:14 AM   #1000
Here are some progress shots of the absorbent panels, one completed so far
Basic frame with backing fabric attached (excuse the perspective the divider is in the middle of the frame)
Full Range TC9 Line Array CNC Cabinet-img20191018130140-jpg
Filled with fibreglass insulation
Full Range TC9 Line Array CNC Cabinet-img20191018130646-jpg
Front fabric attached
Full Range TC9 Line Array CNC Cabinet-img20191018135911-jpg
In room next to array for scale, even with no bracing these things are awkward to move around.
Full Range TC9 Line Array CNC Cabinet-img20191018140310-jpg
Full Range TC9 Line Array CNC CabinetHide this!Advertise here!
Full range line array inrank Full Range 43 16th November 2017 08:25 AM
Full range line array in a tube carpenter Full Range 44 7th January 2014 03:19 PM
Omni full range line array??? Melo theory Full Range 42 25th November 2012 06:44 AM
Full-range line array? mazeroth Full Range 20 1st November 2004 04:47 PM
line array with full range drivers? leadbelly Multi-Way 9 25th January 2003 05:48 PM
Copyright ©1999-2019 diyAudio
