Mark Audio Alpair 7.3 or Pluvia 7
Thread Tools
Old 17th September 2016, 11:33 PM   #1
montana1 is offline montana1  United States
montana1's Avatar
Default Mark Audio Alpair 7.3 or Pluvia 7
Hi To All,
I'm trying to decide which of these to MA drivers will work best in my next project (darn hobby keeps on growing) What I'm looking at building is a small mini tower 24 inches tall by 6.75 wide by 8 inches deep to augment into my current FAST setup. These speakers will serve as rear surround speakers in a HT setup with an eye on later transition to a 4 channel stereo system. Bass duty is covered by Dayton Audio RS225-8" woofer so MA drivers will be used to support mid range and treble duties. It seems that the A7.3 has an edge in the sound quality department. If the consensus is the A7.3 is that much superior to Pluvia7; I would not hesitate to spend the extra cash. Any comments are always much appreciated! Thanks in advance.
Rich
Old 18th September 2016, 05:34 PM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
The P7 sounds much like the A7x but the latter is capable of producing greater levels of detail & nuance. For just the rear channels that may not be needed (ie an A7 front row and P7 in the back should work fine).
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 19th September 2016, 02:32 AM   #3
montana1's Avatar
Dave,
Thanks very much. I'll probably then purchase the P7 for this build. Would you recommend a sealed enclosure in this application? Again, I'm not looking for maximum bass extension.
Best Regards,
Rich
Old 19th September 2016, 02:51 AM   #4
frugal-phile(tm)
planet10's Avatar
Id probably do a vented enclosure.
dave
Old 19th September 2016, 03:07 AM   #5
chrisb is offline chrisb  Canada
Enclosure volume and tuning would be?
Its been a slice kids
Old 19th September 2016, 03:21 AM   #6
frugal-phile(tm)
planet10's Avatar
5-13 litres. We have our own tuning.
This is the plan for the 13 litre Classic Golden Ratio. Other plans are part of the paid planset. The enclosure name is going to change to CGR Plu-Ken7.
http://www.planet10-hifi.com/downloa...-15-030216.pdf
Estimated F10 40 Hz.
dave
Old 19th September 2016, 01:19 PM   #7
montana1's Avatar
Chrisb,
Based on measurements from my first post, internal volume would be approximately 11 liters. Looking at tuning to around 90-100 hz. Thanks, Rich
Old 19th September 2016, 01:27 PM   #8
montana1's Avatar
Hi Dave,
Thanks for all the valuable information you have provided. I have been modelling the P7 in Unibox and it appears like a sealed alignment helps control excursion. You may have methods to combat over excursion in vented alignment. In Unibox given 10watt nominal power, xmax is exceeded at around 80 hz in a vented alignment. I'm as green as grass when it comes to this stuff, just trying to gather a better understanding. Best, Rich
Old 22nd September 2016, 12:12 AM   #9
Wiggle8 is offline Wiggle8  Canada
dave
So is it safe to assume that the the Pluvia 7 could make a good choice for the center and surrounds to support a pair of Alpair 7 for the main stereo pair?
Old 22nd September 2016, 01:11 AM   #10
frugal-phile(tm)
planet10's Avatar
Not the centre, that wants to be the same as LR, but certainly for the surrounds.
dave
  Reply to this post
Mark Audio Alpair 7.3 or Pluvia 7Hide this!Advertise here!
Thread Tools
New Mark Audio Pluvia Seven IRONHAND54 Full Range 278 13th January 2019 10:54 PM
Mark Audio Pluvia Seven Mar-Ken Sketches planet10 Planet 10 hifi 37 24th July 2018 09:29 PM
TS Parameters for Mark Audio Pluvia 7 or Alpair 7? Veleric Full Range 5 15th April 2016 10:50 PM
Mark audio alpair 7p vs alpair 7.3 sarathssca Full Range 157 21st March 2016 02:24 PM
Which Mark audio Alpair ? Ewald Full Range 20 14th May 2011 08:36 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
