How about quarter round moulding for internal corner bracing?
Old 8th July 2016, 04:41 PM   #11
jimbro is offline jimbro  United States
That driver only goes up to 10k. What are your expectations and application?
Old 8th July 2016, 04:51 PM   #12
chrisb is offline chrisb  Canada
No - I tend to always countersink the driver basket for flush mounting - what I meant was don't recess the front panel so the sides / top/bottom are proud, which is something often seen with inset grille frames. That would generate a lot of diffraction issues
Dadoes for insetting back and front panels would require very little extra effort for an experienced woodworker, which along with biscuits or continuous splines along the beveled joints would significantly strengthen the cabinet.
I build a lot of small boxes from 15 & 18mm plywood myself, and on very small FR drivers such as the usual candidates for something like this, even 12mm is sturdy enough - but with that material I generally use simple butt joinery & dadoes
Don't place bracing members, dowel or otherwise at exactly the middle of any panel, and add a short, slightly larger diameter brace between the magnet and back panel - test fit with driver's gasket properly compressed
I've never heard the Auratone, so can't speak to its mythical popularity - it is a tiny, potentially cute little box.
Have fun with the build
edit:
ps per jimbro's comment - there are probably other candidates for drivers for such a little project that would have much more extended HF response - Fostex, TangBand, Fountek, Vifa, ScanSpeak, Dayton, Mark Audio to name just a few. in such a very small sealed cabinet, you should also be prepared for limited bass response without use of massive EQ and power.
We’re just a bunch of monkeys on a big blue spinning ball - Don Caron
Old 8th July 2016, 05:46 PM   #13
oidua5 is offline oidua5  Canada
Thanks again for your thoughts. As with the orig. Auratone, the speakers are meant to be a mids-focused "real world" mixing reference. The idea is that almost all playback systems have mids, so if your mix translates on Auratones, it improves the chances that the mix will translate in a wide variety of settings. Of course the single driver also means no cross-over distortion.
Old 8th July 2016, 05:48 PM   #14
The port-free design may also have something to do with the Auratone's popularity. These waterfall plots show it's unusually even decay, similar to another time-honored mix ref speaker, the NS-10...
Old 8th July 2016, 05:49 PM   #15
For comparison, have a look at the low end decay of these other pro mixing monitors...
Old 8th July 2016, 07:08 PM   #16
fair enough - as you might find discussed in other threads, even the most careful measurements only tell part of the story - but if making a choice on published graphs only - i.e. having heard none of them, I'd be inclined to the ATC SCM20A as the "best" compromise from the group shown
Old 9th July 2016, 08:56 AM   #17
ewollowe is offline ewollowe  Australia
I believe this is the same driver as used in the original?
https://www.amazon.com/GRS-Full-Rang.../dp/B00DVO1OYS
I owned a set of AURATONE 5S before, a garage sale bargain at $5. They had a nice clear sound, no bass.
Different shape to the typical cube.
http://medias.audiofanzine.com/image...-5s-200438.jpg
Old 10th July 2016, 01:39 PM   #18
BYRTT is offline BYRTT  Denmark
BYRTT's Avatar
Agree post 14 verse post 15 has nice decay and that should lead to good clear midrange but also as ewollowe note there is really no bass amplitude. Reason those good waterfall think is low Q variation (roll off) from ideal flat response in minimum phase domain where the higher the Q variation leads to ringing tails, exactly the debate why sealed sometimes can be superior to ported. Imagine those waterfalls are anechoic or near field data so to replicate the fine data real world for final build remember to use it as near field speaker because as i see it as soon as speaker has to cooperate with room then responses from post 15 examples probably integrate better than post 14 will do.
Below picture 1 show some data that help see how lower Q variation is superior to high Q variations.
Picture 2 show example typical room mode data from a free Jeff Bagby spreadsheet verse the 5 times band passes from picture 1 and it looks obvious that green will integrate relative flat with room verse orange that will get a dip that will lead to a new ringing tail in waterfall compared when listening orange in near field.
Picture 3 data is all 2. order BW roll offs and think show the lower and flat extension one can get from speaker system all included at listening position the better the waterfall will show clear mids and audio band data from 20-20kHz (ringing tails get moved so low in frq they out of audio tracks area of energy).
  Reply to this post
How about quarter round moulding for internal corner bracing?Hide this!Advertise here!
Subwoofer enclosure internal bracing rocko1290 Subwoofers 20 22nd February 2017 03:19 AM
if using 1" thick MDF,,is internal bracing still needed? rockironwebb Subwoofers 8 25th October 2013 07:19 PM
Round over bracing holes? Frosteh Multi-Way 3 14th September 2011 04:33 AM
Internal bracing vs SPL firepinch Subwoofers 17 28th November 2006 01:54 PM
bracing of large cabinets and effects on internal reflections JRKO Multi-Way 7 12th April 2005 07:12 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
