Philips AD 8080/m4
Philips AD 8080/m4
Thread Tools
Old 7th July 2016, 05:47 PM   #11
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Philips AD 8080/m4
Sounds like you are describing an OB? Should be OK. The bigger you make it the lower they should go, but there will be an optimum size.
dave
Stay safe. Stay home. Respect the 2m bubble.
Old 7th July 2016, 05:51 PM   #12
sachu888 is offline sachu888  India
sachu888's Avatar
Default Boston Acoustics HQ48002
I am also looking to suggestion for Boston Acoustics HQ48002. Earlier they used to come as Philips Hi Q International speakers, now BA has acquired Philips speakers here, so the name changed. I have posted here because TS looks similar to OP's drivers.
Someone posted TS parameters of HQ48002 on another Hifi forum.
Fs = 83.86 Hz
Re = 7.10 ohms[dc]
Le = 787.75 uH
Qes = 1.46
Qms = 6.12
Qt = 1.18
Mms = 9.70 grams
Rms = 0.834214 kg/s
Cms = 0.000371 m/N
Vas = 26.88 liters
Sd= 226.98 cm^2
Bl = 4.980546 Tm
Sensitivity(2.83V/1m) = 92.80 dB
My friend has ried them in 40 Lt front ported bass reflex enclosure. I think similar like 7910 enclosure, but bass was not upto the mark.
Sachin
Old 7th July 2016, 05:55 PM   #13
frugal-phile(tm)
planet10's Avatar
Philips AD 8080/m4
Qt = 1.18
Vas = 26.88 liters
The Q on this is a bit lower. As big an aperiodic box as you can live with. You aren't going to get deep bass out of these with an Fs near 90.
They would work in an OB too, but would likely need bass help.
dave
Old 7th July 2016, 05:55 PM   #14
Lohengrimas is offline Lohengrimas  Netherlands
Maybe a transmission line in the vein of the TABAQ would be cool... Bjohannesen explicitly designed those around high q drivers (tang band) with not too much extension.
Old 7th July 2016, 06:17 PM   #15
sachu888's Avatar
Thanks Dave. I think will looks for another driver then.
Sachin
Old 21st July 2016, 05:53 PM   #16
sachu888's Avatar
Hi Dave,
I recently got another 8" FR drivers. Someone has posted TS parameters on another forum.
Bolton 20BF22 8ohms 40W Fullrange
Thiele-Small parameters:
Fs = 58.93 Hz
Re = 7.70 ohms[dc]
Le = 352.98 uH
L2 = 469.44 uH
R2 = 3.77 ohms
Qt = 1.35
Qes = 1.68
Qms = 6.81
Mms = 13.70 grams
Rms = 0.745250 kg/s
Cms = 0.000532 m/N
Vas = 30.23 liters
Sd= 201.06 cm^2
Bl = 4.817540 Tm
ETA = 0.35 %
Lp(2.83V/1m) = 87.75 dB
Fm friend is using same drivers in Sealed 35Lt enclosure. He has posted a video here https://www.youtube.com/watch?v=3Ex9s_ZsP1k
Can you suggest me any good enclosure fr them.
PS: My drivers are 4 Ohms.
Sachin
Old 21st July 2016, 06:47 PM   #17
frugal-phile(tm)
planet10's Avatar
Philips AD 8080/m4
Qt is > 1 which indicates an OB of some sort.
dave
Old 21st July 2016, 06:56 PM   #18
sachu888's Avatar
Thanks Dave, can I put them in sealed design as space is concern for OB.
Sachin
Old 21st July 2016, 06:58 PM   #19
frugal-phile(tm)
planet10's Avatar
Philips AD 8080/m4
If you can't put them in an OB, an aperiodic box as large as you can live with is your best bet.
dave
Old 21st July 2016, 07:02 PM   #20
dave
Yes, that's why I was wondering if a TABAQ (WiBAQ?) enclosure would be suitable, since that is also designed for a high Qts/100+ Hz driver. Bjohannesen mentioned a 2:1 ratio for the lowest reach vs the rating of the driver, so something like a 47/48 Hz low end should be possible in a TABAQ-style enclosure with the 8080, if I read the docs right. Probably not, since I'm a n00b of the worst kind...
Philips AD 8080/m4Hide this!Advertise here!
Thread Tools
FS: NOS Philips 5061-M4 5" Fullrange speakers ARIYAHOOR Swap Meet 4 12th May 2015 09:28 AM
Philips AD 7063 ideas Mayuri Full Range 10 5th February 2015 07:39 PM
Philips 12202/M8, 12202/M4, Pair Philips 9750-05 knarfor Swap Meet 5 17th November 2014 08:01 AM
Philips AD 80800/M4S ElTurko Full Range 10 25th October 2014 05:25 PM
WANTED: AD 0211/SQ4 ; AD 0163/T8 for philips MFB vintage anton-sa Swap Meet 3 28th February 2008 04:51 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
