New Mark Audio Pluvia Seven
Old 30th December 2015, 07:57 AM   #11
ChuckORWC is offline ChuckORWC  United States
I sent you an email about the EL70eNs. Since they're probably beyond my budget, a Pluvia optimized Derwent would be of great interest to me and probably many others...
The ~9" depth of the Derwents is really appealing to me. At the listening distance, angling the FH3s sufficiently would probably put them too far off-axis. Also, there's actually a stairway opening off to the side behind the right speaker, which also complicates matters.
Anyway, don't want to take the thread too far off the Pluvia topic.. they look like promising drivers at a reasonable price.
Thanks again.
Old 6th January 2016, 04:07 PM   #12
Wiggle8 is offline Wiggle8  Canada
I was initially looking to build a ported CHR-70 arrangement and saw that this driver has just been released. I see the Pluvia is not recommended for ported enclosures though which is what I had been leaning towards. Perhaps someone can recommend which driver and box arrangement I should be looking at for my application.
I would like to build a pair using a single full range driver each speaker. They will be installed on wall mounted shelves approximately 10" square foot print. A form factor that sits on this shelve without overhanging and leaving a half inch or so to route speaker cable would be best. So depth should be approximately 9". I am leaning towards sealed or front ported. Since these will be wall-mounted something slightly thinner in the bass region may be a good idea.
They will be used mainly for radio/podcasts and music for when guests are visiting. Low volume only.
Old 6th January 2016, 04:31 PM   #13
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
I don't know where Madisound came up with the comment about it being unsuitable for vented boxes. Either somebody got the wrong end of the stick, or based that comment on EBP (which is at best a massively over-simplified approximation). There is absolutely no technical reason why this unit can't be used in a vented box.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 6th January 2016, 05:32 PM   #14
chrisb is offline chrisb
An excellent example of vented enclosure being a BLH such as the FH3. I'm glad we tried them there before reading it was not recommended.
I found they work quite well in the horn- albeit not quite as extended in the bottom, or as resolving as the A7.3, but certainly an improvement to my ears over the CHR70.3
Have we reached the point of embarressment of riches in the category of small full-range driver, as imperfect as some measurements will inevitably prove the class and specific examples to be?
Yes, that's a rhetorical question.
Fate - something that people make up to try to explain how things worked out
Old 6th January 2016, 05:39 PM   #15
I am thinking of building the Pluvia 7 into the "slim-deeper bass reflex box" listed here:
CHR 70 Metal | Markaudio
I may just modify the depth to be 1/2" shorter to accomodate my shelf, I can widen the front slightly to compensate for the slight amount of volume loss.
Old 6th January 2016, 05:53 PM   #16
Just keep the net internal volume the same, and you should be fine.
From my experience with a fair number of other FR drivers in this approximate size class, if you could possibly afford the floor space required, a full length MLTL or BLH would deliver deeper and more articulate bass. The FH3 also produces a very nice soundstage.
Old 6th January 2016, 05:59 PM   #17
Thanks for the info. Due to room contraints I'd like to keep with the bookshelf style. I do understand the advantage of the floor mounted styles with the tall enclosure. I built 5 channel set of creativesound speakers (V2 MTM center, V2 MLTL and V1 bookshelf) and the extension on the V2 MLTL is very impressive, especially considering the mid/woofs are only 4" diameter (CSS VWR126X) .
Old 6th January 2016, 06:58 PM   #18
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I would be wary of putting pluvia in a vented box for any other driver. I have yet to rework the miniOnken for this driver, but it is closer to the EL70 than the CHR70 as far as boxes go. You could put it in that volume but you would very likely need to change the tuning.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th January 2016, 09:53 PM   #19
Would the port diameter likely change or just the length?
Old 6th January 2016, 11:46 PM   #20
frugal-phile(tm)
planet10's Avatar
Likely just a change in length. 7.5 litre they say tuned to 57 hz.
The factory tuning has a bit of a bump in it -- ideal if you use a high aspect ratio vent to knock it down (full width, 12mm tall, 147mm long). 1.5" (38mm) plumbing pipe is easy to get, 113 mm long but bass may be a bit fat, maybe boomy (vrs the slot).
dave
New Mark Audio Pluvia SevenHide this!Advertise here!
Some nice speakers. Audio Tech C-Quenz, Mark Audio, Peerless vactor Swap Meet 32 8th March 2014 03:40 PM
Mark Audio Mark-Ten or Holly65 with the Gardient AXT-08 Ronald67 Full Range 4 11th January 2014 09:01 AM
mark audio chr 70.3 vs dayton audio rs-100 f16voodoo1 Full Range 8 22nd November 2013 05:23 AM
need some mark audio help osd1 Full Range 9 9th August 2013 03:15 AM
Mark audio I am looking at two of your drivers help please. phil09 Full Range 14 11th June 2011 03:09 AM
Copyright ©1999-2019 diyAudio
