:-( my (fe126en) FrugalHorn mk3 boxes sound wore than small boxes
Old 12th December 2015, 01:23 PM   #21
jimbro is offline jimbro  United States
What are the panels on the wall? Could they be absorbing bass? Also make sure the fh3's are in the corners (I'm sure you know that!).
Old 12th December 2015, 03:25 PM   #22
Ensoniq is offline Ensoniq  United States
3/4" panels. I can't put then directly in the corners since I have bass traps, (and diffusers and absorbers on walls).
also besides the screws that are clearly seen, I nailed the boards with Finish nails.
Old 12th December 2015, 03:39 PM   #23
I'm thinking of switching drivers.. which ones for the similar price and same size are compatible with FH mk3 ? with more bass
Old 12th December 2015, 04:09 PM   #24
zman01 is offline zman01  Bangladesh
You can check out this one:
https://www.madisoundspeakerstore.co...l-range-8-ohm/
A little higher priced than the FE126En. IIRC P10 and Chrisb tried it out in the FH3 and found it a good match - they would be able to comment.
Old 12th December 2015, 06:50 PM   #25
Ray21 is offline Ray21  United States
Alpair 7 costs a bit more, in comparison, but I think you'll find no lack of bass with that driver. Cutout is nearly identical to the FE126en.
I ran the FE126en in a BK12 for about a year and switched to the MA A7 in the FH3 and much prefer the Alpair. Better bottom, better top - though the better bass is certainly a function of the FH3.
The FE126en is by no means a bad driver, IMO, and has a very pleasant sweet spot at a particular volume level, but runs out of steam very quickly.
Old 12th December 2015, 10:14 PM   #26
chrisb is offline chrisb  Canada
Alpair 7 definitely gets my vote sonically - it and the exotic MOAP7 are my personal favorites for the FH3, but note that its through hole is slightly larger than the FE12x series, and more importantly, it has a very thick mounting flange which really needs to be flush with baffle surface, so it's not just a drop in.
An easy alternative would be the Fostex FF125WK, which is exactly the same frame size, and while slightly lower sensitivity will probably do a better job in the bass department.
Ray, agreed that the 126 is excellent in the right application, but I think the A7.3 will deliver better bass in any enclosure of equal size - at the price of both sensitivity and dollars.
Itís been a slice kids
Old 13th December 2015, 12:19 AM   #27
vinylkid58 is online now vinylkid58  Canada
vinylkid58's Avatar
Add the Fostex FX120 to the "more bass" list of drivers, although they are getting a bit more spendy as time goes by.
jeff
Old 15th December 2015, 07:17 PM   #28
FYI - some folks have built a rear deflector and stuck a "stealth" woofer in it for a FAST.
Old 15th December 2015, 08:05 PM   #29
some folks - now, to whom would that be referring?
Old 15th December 2015, 09:56 PM   #30
I was trying to keep it stealthy but I guess the cat's out of the bag now!
:-( my (fe126en) FrugalHorn mk3 boxes sound wore than small boxesHide this!Advertise here!
1 big box Vs 2 small boxes. JoeM Subwoofers 15 9th September 2020 01:37 AM
Built some small vented boxes for FF85WK IG81 Full Range 29 5th April 2015 11:03 PM
Fostex FF125WK Speaker Boxes / Planet 10 FF125WK Drivers/Boxes jonparkhurst Swap Meet 2 23rd August 2013 06:19 PM
Newibe Help with small fullrange drivers and boxes please? Boo 92 Full Range 13 11th July 2013 05:39 PM
Rear horn boxes for small Tannoy hamradioman Full Range 6 19th October 2012 11:26 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
