What would larger woofer caps do here?
Old 23rd October 2015, 02:29 PM   #1
reiver is offline reiver  United States
Default What would larger woofer caps do here?
I have an old pair of Klipsch Fortes 2's I'm refreshing. For now I'm just replacing the electrolytic cap in the woofer circuit, its 24 years old after all. Its a 12db slope with a 2.75mh coil and 110uf 10% capacitor. 4ohm woofer I believe.
Here's my question: After I pulled the caps out I put them on my meter...one read 124uf and the other 130uf. I realize its not earth shattering, but what would have been the effect of having these drifting, larger values on the woofer instead of the expected 110uf?
(prob should have put this in the multi-way forum...but I can't delete it)
Old 23rd October 2015, 03:57 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
I doubt you will notice any difference as they are close to the values required. Caps don't usually increase in value, they decrease with age.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 23rd October 2015, 04:28 PM   #3
Could be that Klipsch's KSC (King-Sun) caps were not too accurate to begin with. The schematic calls for 110uf which is an odd value...at least I have them matched now.
Old 23rd October 2015, 06:01 PM   #4
badman is offline badman  United States
badman's Avatar
It won't be a big thing. If you want upgrades, a low DCR air-core inductor (14 awg) on the tweeter circuit, and better, possibly charge-coupled caps there, would probably be your best bets. If you want to get more in-depth, Bob Crites, I believe, has tweaked some of the classic Klipsch XOs to good effect.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
  Reply to this post
What would larger woofer caps do here?Hide this!Advertise here!
Larger Caps mod - worth it? Sane? alwaysultra Solid State 12 4th December 2014 09:03 PM
Do larger caps age better then small ones? AltecDarpa Power Supplies 20 9th September 2011 05:02 AM
Audible benefits of larger coupling caps than required? DrewP Parts 54 10th July 2011 07:48 AM
Simple question, filter caps larger than spec kvk Power Supplies 2 26th February 2008 09:06 PM
Leach but larger taj Solid State 18 8th May 2007 07:06 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
