Philips AD12202 M15
Philips AD12202 M15
Old 31st October 2015, 05:05 AM   #21
GM is offline GM  United States
GM's Avatar
Originally Posted by beto1 View Post
Thanks GM.
You're welcome!
He wrote in detail what I summed up in a few words . BTW, in the early days there were 5-6000 ohm matching impedance drivers, but as power increased to drive studio monitors, cinema sound they were abandoned once stock was used up. Still, they [use to now?] pop up occasionally on ebay.
Anyway, found my old Lotus 1-2-3/Excel SS that calculates this stuff, but without driver specs all I can tell you is that for a given set of Fs, Vas, Qes, Re specs, doubling Re doubles Qes, efficiency drops 3 dB [half power], so typically this is the max loss where:
Re = measured voice coil resistance
Rs = total added series resistance [wiring, XO components, amp output impedance]
Qes' = Qes*(1+Rs/Re)
n0 = 9.6352*10^-10*Fs^3*Vas/[Qes']
SPL = 112.018+10*LOG(n0)
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 31st October 2015, 08:10 PM   #22
beto1 is offline beto1  Chile
beto1's Avatar
Thanks again GM.
Then, roughly, we can say that you could lose 3 dB using a 15 ohms on a 8 ohm amplifier tab. It would not be a problem if is sensitive enough. But I found the full parameters developed in a French site. According to them, is not 100 dB but around 97. Paramètres haut-parleur de THIELE et SMALL, sans filtre ni ampli
This model is about parameters from the 8 ohms model, but we can approximate the Re and the nominal voltage for the 15 ohms, based on the progression of this parameter on the 4 and 8 ohms models. Increasing this voltage by raising the impedance output transformer almost doubled, is the point that concerns me, more than the loss of efficiency in terms of the general sound pressure or how loud I can hear my amp. Because if I understood well, increasing voltage and temperature in the voice coil would produce differences in the sound attributes also. In a second term, if I have 97 dB ,if I lose 3 dB, would have 94 dB. I believe is enough if the impedances didn't drop too much across the frecuency range.
I found this paper also, about the temperature on the voice coil that I'm reading now. (at the same time I'm trying to learn Ohm's law, Kirchhoff's rules, etc in an express way) http://epubl.ltu.se/1402-1617/2008/0...X-08096-SE.pdf
Thanks you again for your very informative insights.
Old 31st October 2015, 08:15 PM   #23
beto1's Avatar
Originally Posted by David McBean View Post
Hornresp calculates the increase in voice coil resistance due to the coil being heated above the standard reference value of 20 degrees Celsius. The value of the increased voice coil resistance due to heating is displayed in the status bar panel at the bottom of the input parameters window when the mouse pointer is moved over the Re text box
Thank you David for the explanation. I'm gathering all the information needed to take advantage of your software.
Best regards
Philips AD12202 M15Hide this!Advertise here!
Philips ad12202 M8 port length? microdub Full Range 11 13th September 2015 10:11 PM
Tannoy M15 tweeter replacement sicleaver Multi-Way 14 27th September 2014 10:08 AM
New cabinets for Tannoy M15? OzMikeH Multi-Way 11 17th January 2009 02:54 PM
Advice for Philips AD12202-M8 edlye Full Range 5 14th September 2007 12:19 AM
