Frugel-horn XL driver?
Old 18th September 2015, 12:45 PM   #1
ColinA is offline ColinA  United Kingdom
Default Frugel-horn XL driver?
What do people think of the Alpair drivers in the XL.
10m or 10p?
This would be for use in a largish room with a 2A3 SET amp.
(I do not need them to go very loud!)
Any other options with a UK supplier?
Judge quality with your ears not instruments or simulators
Old 18th September 2015, 01:13 PM   #2
zman01 is offline zman01  Bangladesh
ColinA,
AFAIK Oak Audio carries MA driver in the UK:
Markaudio Drivers | Product Categories | Oak Audio
Both the Alpair 10P and 10.3 work fine in the FH-XL, the Alp 10P is slightly more efficient.
Old 18th September 2015, 05:15 PM   #3
chrisb is offline chrisb
Having heard both in the XLs, I can confirm Zia's comments - in your case, the paper driver's additional sensitivity could be the determining factor between the Alpairs. The Fostex FF165WK also works well, and has an additional almost 4db of sensitivity over the 10P - along with the famous Fostex flavouring.
Fate - something that people make up to try to explain how things worked out
Old 18th September 2015, 06:37 PM   #4
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
As to driver sensitivity. Drivers i have had here and measured put:
A10p just over 90 dB.
A10.3 just over 87.5 dB.
FF165wk just over 91 dB.
As to the 10s in FHXL, it is 6 of one, half dozen of the other, they have a different set of compromises. The A10.3 takes much longer to break-in so an early comparison gives the A10p an edge.
The use of 2A3 SE would give the paper an edge, but even in my big room, we were happy with Bernie's 2A3 SE driving the even less sensitive A7.3 except when the wick was turned way up. How well your amp clips will play a role then.
An externally hosted image should be here but it no longer works. Please upload images instead of linking to them to prevent this.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th September 2015, 10:14 PM   #5
well, there you go - published and real world measured sensitivity specs not always agree
Old 22nd October 2018, 05:25 AM   #6
logotrikes is offline logotrikes  Australia
Hi folks,
With regard to using the Fostex FF165WK in the FHXL, I'm a huge fan of Fostex and used them several times. However, as good as Fostex are, nothing screams 'cheap' like a silver dustcap, and I can't see the thinking behind equipping a quality driver with such a thing. Maybe some sonic benefit?
Nevertheless a silver dust cap rules out the FF165WK for me...
My question therefore, is the FE166EN a suitable replacement? I'm sure it would be, but many of you guys have rather more experience than I and can comment definitively.
I rather like the Sigma variation but too expensive for me, and the FR looks very lumpy.
I always dope the cones with some recommended artists varnish in an effort to stiffen up the cone, bypassing Fostex's intense R&D cos I think I know better
Anyway enough of that, just asking for recommendations...
Cheers guys and greetings from Australia. Martin
Old 22nd October 2018, 06:42 AM   #7
frugal-phile(tm)
planet10's Avatar
Like the FH3 with FE126En, you need to maximize bass potential if you use FE166En or FE168e∑ — both of which people say works fine. Of the 3, i prefer the sound of the FF165wk. The metal dustcap is to extend the top with no whizzer… and it works pretty well.
dave
Old 22nd October 2018, 06:57 AM   #8
Default FF166WK
dave
Cheers Dave, I'm glad of a considered opinion..
Still, I have trouble with the FF165WK. If somehow I could hide or disguise the silver dustcap I might consider it.
For a bit of background, I'm 71, my hearing is far from optimal and I have quite severe tinnitus. So to me it might not make a difference whatever I chose.
I thoroughly enjoy my music and still hear some sparkle from my Fostex fe103en towers. They're TQWT's I built many years ago, and I'm sort of used to them.
The idea of the FH in any iteration has been a fascination for years, so I'm seriously thinking of giving them a go.
Many thanks for your views Dave.
Cheers, Martin
Old 22nd October 2018, 07:07 AM   #9
frugal-phile(tm)
planet10's Avatar
… or disguise the silver dustcap I might consider it ...
It might be possible to paint a thin coat of acrylic train paint on it. It will likely be a bit streaky. Carefully clean with 99% isopropyl first (i’d use a Q-tip).
You might loose a bit of top but that doesn’t sound like that will hurt in your case. On my drivers i put a specific set of spots and then a coat of clear gloss acrylic. You can see the dot pattern i use in the top frame of these “red” FF165wKeN. These are the spots where the tap test says there should be an EnABL pattern.
Now you are likey not to by a driver just so that you can see if acrylic works. I might try that for you.
dave
Old 22nd October 2018, 10:11 AM   #10
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Yes. It's a given alloy formed into a specific profile direct-coupled to the voice coil (i.e. it's a tweeter). The alloy type for such uses is specific; anodising or similar can change behaviour, so altering the colour to something unspecified may not be practical, as well as increasing costs (& thereby the retail price).
You could try a magic marker. My friend Colin managed this with a set of Monacor cone tweeters; the results were OK-ish, although I can't say it bothered me.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Frugel-horn XL driver?Hide this!Advertise here!
Frugel-Horn XL for Alpair 10.3/10p, Fostex FF165wk, more planet10 Full Range 1094 10th January 2019 05:57 AM
Frugel-Horn XL for Fostex Fe 168eZ pehajope Full Range 39 25th January 2016 03:49 PM
frugel-horn driver selection tamahaac Full Range 13 1st July 2015 12:06 AM
Frugel-horn XL build falcoron Full Range 5 17th December 2014 06:23 PM
Copyright ©1999-2019 diyAudio
