JX 92S Advice
Re the reflex pipe - don't forget we're only interested in the internal size. An alternative is to laminate pieces of wood together to the correct length and use a suitable bit to make a hole through them. Make sure the hole is smooth (perhaps give it a coat of varnish) and take into account the volume of the block of wood.
In a former life I engineered classical music competitions broadcast live from Orchestra Hall in Detroit. The critical musical contribution of the back of the stage in width, height and power was immediately obvious even on the simplest solo instruments. IMO the music industry erred when it insisted on two extra channels behind the listener and demonstrated their value by mixing instruments never there in real life. Speakers three and four should have gone outside and above the main left and right speakers.
The BBC have been running experiments with surround and broadcast the last couple of Proms in surround via their online feed using four loudspeakers.
BBC Proms 2016 in surround sound - E J Jordan Designs
