Frugel-Horn Lite for 3" drivers
Old 31st December 2018, 10:06 AM   #211
Jishu is offline Jishu
Would the Frugel-Horn Lite work if the back is not a wall but a big window? I know so little about about horns, and came to know Frugel-Horn needs loading from the back wall? The window is always closed, if that helps.
Thank you!
Last edited by Jishu; 31st December 2018 at 10:07 AM. Reason: forgot to write, "Thank you!"
Old 31st December 2018, 04:58 PM   #212
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
A good question. How close to the floor do the windows reach? The glass will certainly be more transparent to the bass than a solid wall.
We have gotten away with 42” high fake walls of our back deck, so with a bit less damping and closer to the wall you will likely be OK. Depends somewhat on the driver used.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th January 2019, 08:56 AM   #213
Sorry. From the floor the wall extends to 22 inches and then the window starts, the window is 60 inches high and 54 inches wide. I would be using the Vifa TC9FD for my frugel-horn lite build.
Thank you!
Old 5th January 2019, 05:35 PM   #214
frugal-phile(tm)
planet10's Avatar
You should be OK.
I would suggest considering the removable baffle. We found the TC9 a very dissapointing driver — i know some rave over them — at some point you might want to put something better in them.
dave
Old 5th January 2019, 09:02 PM   #215
frugal-phile(tm)
planet10's Avatar
I haven’t heard it, but the FE88ex i have and it is. The FE85 is used as a midTweeter in some expensive commercail WAWs, so one would hope is closer to its sibling, than to the VIFA. The TG9 is another upgrade. I liked the Aura NS3 as well, those live on as Dayton branded product now. Not necessarily exactly the same: Dayton Audio ND90-4 3-1/2" Aluminum Cone Full-Range Neo Driver 4 Ohm
The best drivers we have heard are FF85wk and Alpair 5.2 (or FF85wKeN/A5.2eN), one i’d really like to hear is the Audience A3 (unobtainium). Haven’t heard them in FH-Lite but i fully expect Alpair 6.2m/p kick *** too.
There are tons of 3-3.5” drivers out there that i haven’t heard but i am leary of trumpeting others enthusiasm after our TC9 experience.
dave
Frugel-Horn Lite for 3" driversHide this!Advertise here!
Pics Carfrae Little Big Horn "Lite" - kit atilsley Full Range 7 1st October 2017 11:52 PM
Frugel Horn for Lowther drivers ziocalepino Full Range 8 23rd August 2012 09:33 PM
FS: Frugel-horn MK3 Flatpacks with EL70eN^2 Drivers wiatrob Swap Meet 1 27th August 2011 07:00 PM
"straight" frugel horn mk3 mahleriana Full Range 10 15th April 2011 01:28 AM
Commercial "Tribute" to the Frugel-Horn? klykx Full Range 85 4th August 2010 09:28 AM
Copyright ©1999-2019 diyAudio
