10F/8424 & RS225-8 FAST / WAW Ref Monitor
Thread Tools
Old 14th October 2021, 04:59 PM   #3221
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Originally Posted by jimk04 View Post
Or PS95.......Ad infinitum!
Yes, another good one.
RS100-8, FR88EX-8, Tang Band W3-xxxx, etc…
Old 14th October 2021, 08:19 PM   #3222
Kokanee is online now Kokanee  Canada
Kokanee's Avatar
Thanks for the info X and Zman,
It seems like the door is wide open for choices for the full ranger. I assume it does not matter if the FR is 4 ohm or 8 ohm?. I am sure like most folks, I look for the best bang for the buck, but in this case, from all the comments, I may be influenced by the higher quality(ie sensitivity, dB, frequency, etc) and hence the higher price tag.
The only caveat to the above: my old ears are not as good as they used to be, so may not be able to appreciate the higher frequencies that others may hear. tough decision!!
MM
Old 14th October 2021, 08:28 PM   #3223
Plott is offline Plott  Austria
Have to find one :)
Plott's Avatar
So, the B80 are here too, everything is collected now. I could start, if... yes, if I could get the wood parts. I asked about 10 carpenters here in Vienna and neighborhood - no birch ply is available... so project is on hold.
Istvan
DIY-gear: 2x ACA bridged, Frugal Horn Mk.III, XRK FAST TL
Old 14th October 2021, 09:14 PM   #3224
Got Foam?
xrk971's Avatar
The driver needs to be 8ohm to be compatible with the crossover.
Some people have used non Baltic birch plywood or even MDF with veneer. But BB is best for durability.
Old 16th October 2021, 12:14 AM   #3225
Kokanee's Avatar
Hi X,
Is the Xover in the 1st post " Transient Perfect 1st order" dated Jan 11, 2018 for the 10F/8424 & RS225-8 Fast REF Monitor the one to use for parts ordering for the TL, or is there one for the TL that I am not aware of?
MM
Old 16th October 2021, 01:37 AM   #3226
Got Foam?
xrk971's Avatar
Same XO for sealed and TL. The BOM has a typo. You need 6x 2.2uF caps as two are used for the 4.4uF value.
Old 16th October 2021, 06:59 AM   #3227
Kokanee's Avatar
Thanks X,
i must be a little thick, What is meant by:
" R4 is intrinsic to L4" and,
" R5 value 470m." and,
" S1m and S2m"
Thanks for the clarification
MM
Old 16th October 2021, 08:31 AM   #3228
jimk04 is offline jimk04  United Kingdom
R4 is the DC resistance of the inductor.
470m means milliohm so 0.47ohm
S1 ans S2 are thr driver designations within the software.
And indeed I used 6 x 2.2uf per channel, 2 in parallel for the 4.4uf.
Salas DCG3, Ian Canada streamer, JLE 3255, Dibya Xmas TDA7293, Miro AD1862, diy XRK Ref Monitors. B&W DM14, Currently building Pass AB100, Wayne's BA18 and maybe F3
Old 16th October 2021, 02:25 PM   #3229
zman01 is offline zman01  Bangladesh
MM,
Example of an inductor with 1.2R DC resistance:
Dayton Audio 4.0mH 18 AWG Perfect Layer Inductor Crossover Coil
Old 16th October 2021, 05:22 PM   #3230
wesayso is offline wesayso  Netherlands
wesayso's Avatar
6 in total, for two speakers, right?
2x 2.2 uf for C3, 1x 2.2 uf for C1. For two speakers that's 6 2.2 uf caps?
Use Science to design your speakers and they will sound like a piece of Art...
10F/8424 & RS225-8 FAST / WAW Ref MonitorHide this!Advertise here!
Thread Tools
Looking for 18W/8424 THD graphs Piotr Multi-Way 2 17th July 2018 12:00 PM
ET Build: Ripole sub & SS 10F/8424 Mayuri Multi-Way 63 26th January 2018 02:32 PM
FF85WK and RS225-8 Passive WAW / FAST xrk971 Full Range 88 27th January 2017 07:02 PM
ScanSpeak 10F 8424 PVC pipe WAW / FAST tilroh Full Range 10 21st June 2016 04:06 PM
WAW / FAST floorstanding Studio monitor - which woofer? Schlumpfpeter Full Range 45 12th April 2016 09:29 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
