10F/8424 & RS225-8 FAST / WAW Ref Monitor
Old 29th September 2019, 09:01 PM   #1871
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
On XPS foam cabinet only fiberglass stuffing. In wooden cabinets I use the foil covered mass loaded butyl rubber door panel dampening sheets from car audio. I then line with eggcrate foam and then stuff with fiberglass. The works. There are some photos back in the thread that details this. The Dagger pyramid definitely needs the butyl rubber sheets. The Dagger is stuffed with fiberglass or poly fill progressively denser towards the vertex. Leave about 1in open space behind driver and line first 1in of the perimeter of inside of Dagger mouth with felt or melamine foam sponges (magic erasers).
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 30th September 2019, 12:57 PM   #1872
Mas Penk is offline Mas Penk  Indonesia
Noted.. thanks
I think I still have some butyl aspalt rubber for car dampening and 1" Fabric Glass (Grey color).
I also have plan to use some magic eraser pad on inside and some butyl aspalt mat (auto mat??) on outside.
My final thickness is 26mm of plywood. some manufaturer made a wrong thickness and sell it as rejected material.
Mas Penk
Old 27th October 2019, 04:02 PM   #1873
Got Foam?
xrk971's Avatar
If you have these speakers, try playing this drum solo on it. The recording quality is superb despite being only a YouTube clip. You will see the transient perfect nature shine.
YouTube
Thanks to Freddi for pointing out this clip.
Here is also something worth hearing:
YouTube
Old 28th October 2019, 02:14 AM   #1874
perceval is offline perceval  Taiwan
perceval's Avatar
You like drums?
Try this!
YouTube
Old 28th October 2019, 04:04 AM   #1875
baswamin is online now baswamin  India
What am I suppose to search in English? Cause I have RPI and need to search for videos in youtube.
Originally Posted by perceval View Post
You like drums?
Try this!
YouTube
Old 28th October 2019, 04:58 AM   #1876
perceval's Avatar
Can't just key in the address?
The title is in Chinese... no English on that post.
Code:
https://youtu.be/lhOGlmEriUs
On another note, RPI doesn't support any other language than English (or the default language installed)?
In 2019? Really?
That would be a deal breaker for me, if I were looking for a RPI board.
I didn't know.
Old 28th October 2019, 10:58 AM   #1877
Ok, I may have to find out. I am little inexperienced. I am using youtube plugin in Librelec. I will explore.
Code:
In 2019? Really?
I didn't know.
Old 1st November 2019, 04:41 PM   #1878
ontariomaximus is offline ontariomaximus  Canada
X- does the woofer on top and full ranger underneath also hold for other full range options?:
I am thinking 2 separate cabs so I can try many other options to complement the RS225. Even a small 2 way like wolf's Stance (very good speaker)
I have the 10F's, just ordering the RS225's and planning the construction.
Old 2nd November 2019, 12:04 AM   #1879
Got Foam?
xrk971's Avatar
Yes, the arrangement helps with time alignment if woofer is at ear level. So other drivers would use same technique. But if you will be putting the full range in its own cabinet, you can put it on top and move it backwards 3in to achieve the same alignment.
Old 2nd November 2019, 03:31 PM   #1880
My slightly more ambitious idea is 2 use a pair of RS225's per side with a 2.0mh coil and try other uppers. I have lots of amplifier channels so the extra sensitivity of the RS225 pair won't be a problem. Just bi-amp.
10F/8424 & RS225-8 FAST / WAW Ref MonitorHide this!Advertise here!
Looking for 18W/8424 THD graphs Piotr Multi-Way 2 17th July 2018 12:00 PM
ET Build: Ripole sub & SS 10F/8424 Mayuri Multi-Way 63 26th January 2018 02:32 PM
FF85WK and RS225-8 Passive WAW / FAST xrk971 Full Range 88 27th January 2017 07:02 PM
ScanSpeak 10F 8424 PVC pipe WAW / FAST tilroh Full Range 10 21st June 2016 04:06 PM
WAW / FAST floorstanding Studio monitor - which woofer? Schlumpfpeter Full Range 45 12th April 2016 09:29 AM
Copyright ©1999-2019 diyAudio
