10F/8424 & RS225-8 FAST / WAW Ref Monitor
Old 20th September 2019, 06:10 AM   #1861
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Let me edit Post 1 to state it clearly.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 20th September 2019, 04:20 PM   #1862
Mas Penk is offline Mas Penk  Indonesia
On page 1 it is mentioned that internal baffle is 8" meaning with both side attached (thickness total 1,5"), the baffle external is 9.5 ( near 10")
however on post #1856 XRK971 mentioned to stay closed (within 10% tolerance) with external baffle 12"
Mas Penk
Old 20th September 2019, 05:39 PM   #1863
Got Foam?
xrk971's Avatar
Sorry for the confusion folks. The original box was made of 1in thick XPS foam with an 8in internal width. Thus, resulting baffle was 10in wide. If making out if 3/4in plywood, the internal width should be about 8.5in. If I ever said 12in wide that’s wrong. The driver bezel is 223mm or 8.77in dia. 12in would be too wide.
Old 21st September 2019, 01:20 PM   #1864
Elias Zacharopoulos is offline Elias Zacharopoulos  Greece
IMG_20190921_150924.jpga colleague gave me a pair of speakers that remind me of my adolescence. FAST I believe. What do you think about this "oval" full-range alnico speaker (very common in TV sets ) ?
Old 27th September 2019, 03:56 PM   #1865
Initial project.. blade assembling
Mas Penk
Old 27th September 2019, 06:02 PM   #1866
Got Foam?
xrk971's Avatar
Can’t see your picture Mas Penk.
Old 27th September 2019, 07:13 PM   #1867
SredniVashtar is offline SredniVashtar  United Kingdom
SredniVashtar's Avatar
The image opens if you paste the url into a new window.
Old 28th September 2019, 02:03 AM   #1868
Final shape of the dagger... Unfortunately the volume only 0.9 liter. Is that OK or should I make a bigger one?
Blade 2.jpg - Google Drive
Mas Penk
Old 28th September 2019, 02:51 AM   #1869
Got Foam?
xrk971's Avatar
That’s fine,
Old 29th September 2019, 02:57 PM   #1870
X,
Do you use any damping material on enclosure?
Mas Penk
10F/8424 & RS225-8 FAST / WAW Ref MonitorHide this!Advertise here!
Looking for 18W/8424 THD graphs Piotr Multi-Way 2 17th July 2018 11:00 AM
ET Build: Ripole sub & SS 10F/8424 Mayuri Multi-Way 63 26th January 2018 01:32 PM
FF85WK and RS225-8 Passive WAW / FAST xrk971 Full Range 88 27th January 2017 06:02 PM
ScanSpeak 10F 8424 PVC pipe WAW / FAST tilroh Full Range 10 21st June 2016 03:06 PM
WAW / FAST floorstanding Studio monitor - which woofer? Schlumpfpeter Full Range 45 12th April 2016 08:29 AM
Copyright ©1999-2019 diyAudio
