10F/8424 & RS225-8 FAST / WAW Ref Monitor
Old Yesterday, 07:16 AM   #1811
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
I started a new thread for the SB23NRXS45-8 in an OB. I found that a simple parametric EQ makes it fairly flat:
OB FAST with 3.5in Fullrange and SB23NRXS45-8-sb23-ps95-eq-view-1-jpg
-6dB peak at 700Hz and Q=0.60
+6dB low shelf at 250Hz
New thread here:
XRKaudio https://www.etsy.com/shop/XRKAudio
Old Yesterday, 02:19 PM   #1812
Got Foam?
xrk971's Avatar
side by side comparison...
Old Yesterday, 04:55 PM   #1813
sarathssca is offline sarathssca  India
Can this speaker be in the form of slim floor stander and more bass extension?? Or have the woofer be moved to sides for slim floor stander ?
Old Yesterday, 05:50 PM   #1814
Got Foam?
xrk971's Avatar
I would suggest you go with the standard sealed cabinet for a floor stander if you want more bass. The open baffle is a huge loss in bass effciency (-6db per octave starting at 800Hz, so 100hz is =18dB less than a sealed cabinet - to put into perspective). If you want OB bass, you need at least a single 15in or 18in and preferably dual 15in like typical OB systems).
Old Today, 01:15 AM   #1815
sorry my question was not clear, was refering to the sealed stand mount cabinets in my question .. whether we can have them as slim floor standard instead of stand mounts and get more bass extension .. may be ported or mltl ? ..
10F/8424 & RS225-8 FAST / WAW Ref MonitorHide this!Advertise here!
Looking for 18W/8424 THD graphs Piotr Multi-Way 2 17th July 2018 11:00 AM
ET Build: Ripole sub & SS 10F/8424 Mayuri Multi-Way 63 26th January 2018 01:32 PM
FF85WK and RS225-8 Passive WAW / FAST xrk971 Full Range 88 27th January 2017 06:02 PM
ScanSpeak 10F 8424 PVC pipe WAW / FAST tilroh Full Range 10 21st June 2016 03:06 PM
WAW / FAST floorstanding Studio monitor - which woofer? Schlumpfpeter Full Range 45 12th April 2016 08:29 AM
Copyright ©1999-2019 diyAudio
