10F/8424 & RS225-8 FAST Ref Monitor
Old Today, 12:37 PM   #1571
jimk04 is online now jimk04  United Kingdom
I have a pair of Seas L22 RNXP 8 ohm drivers. 88db @2.83v.
Do you think they would take the place of the RS225 satisfactorily with the crossover design on this thread?
Old Today, 02:43 PM   #1572
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
That's a very nice driver, and a first look, being aluminum 8in with a phase plug appears to resemble an RS225 in silver. Let's take a look at the frequency response before we even look at the TS parameters. Here is the SEAS:
Note that there is a sharp drop off at 1000Hz, the XO is at about 800Hz to 900Hz (acoustically) on the 10F/RS225 and being a first order XO, needs a smooth wide bandwidth across the XO region. Also, that sharp peak at 4kHz would really need some serious notch filtering - but indicates this driver was not meant to operate with a low order XO into the mid-range.
Here is the frequency response for the RS225-8:
Looking at the T/S parameters for the SEAS:
Re=6.1ohms
Le=3.76mH
Qms=3.13
Qes=0.29
Vas=93L
fs=21Hz
mms=40g
Sd=220cm2
xmax=14mm(p-p) or 7mm (one-way)
For RS225-8:
Re=6.5ohms
Le=0.86mH
Qms=1.46
Qes=0.51
Vas=56.3L
fs=28.3Hz
mms=35.8g
Sd=214cm2
xmax=7mm (one way)
The main large differences are the Le, Vas, Qes, and Qms - basically a very different driver electro-mechanically. I don't think it will work with the same XO. However, if you measured it and used a simulator program, you could derive a new XO and perhaps move the XO point lower, to say 500Hz (acoustically) to stay farther from the 1000Hz drop-off.
So, this re-affirms an observation that I have had regarding the RS225-8: it is a unique driver that is unmatched at any price and by any brand.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old Today, 03:40 PM   #1573
Thankyou for that in-depth reply. I realise it is seldom the case of using an alternate driver for a given design, but like your first few observations....the Seas seemed to have a little bit in common with the RS!..
I'm not able to measure and XO design is very new to me and hard to get my head around so maybe this is a little too much for me at the moment!
Old Today, 05:09 PM   #1574
perceval is offline perceval  Taiwan
perceval's Avatar
Never too late.
Get a mic, REW software and start measuring.
Then, have a look at XSim. It's a graphical XO design software and you will learn a lot by just playing with it.
Get you DIY skills up to the next level. It will open up a whole new world.
Old Today, 05:16 PM   #1575
It is on my list to be fair. Would love to be able to do more with this fantastic hobby.
Old Today, 09:02 PM   #1576
wxn is offline wxn  Lithuania
wxn's Avatar
Varnish darkened the plywood a bit more than I anticipated. Oh well, I guess I'll just have to pretend it was intended
Nothing is as simple as it seems
Old Today, 09:16 PM   #1577
turk 182 is offline turk 182  Canada
they look dead sexy!
no grill clips or hidden magnets for a grill?
Old Today, 09:34 PM   #1578
Got Foam?
xrk971's Avatar
Nice work Wxn!
10F/8424 & RS225-8 FAST Ref MonitorHide this!Advertise here!
The Nautaloss Ref Monitor xrk971 Full Range 673 12th November 2018 05:42 AM
Scan-Speak Discovery 10F/4424G / 10F/8424G BHTX Full Range 12 25th January 2017 09:32 PM
Dayton RS225-4 & Peerless SLS 8 in woofers, Linaeum, Coaxial omarmipi Swap Meet 9 28th November 2006 05:10 PM
T-Line for Dayton Ref 8" (RS225) dunderchief Multi-Way 20 7th November 2006 08:31 AM
FS: Aurum Cantus G2si Ribbon tweeter (pair) *used* & Dayton 5" ref midwoofer mmdb Swap Meet 1 29th April 2005 09:32 PM
