10F/8424 & RS225-8 FAST Ref Monitor
Old Yesterday, 01:08 AM   #1561
phivates is online now phivates  United States
The racetrack woofers might be smoother in the upper mid than your old school Beyma 8". Looks like a bargain at $42.
Old Yesterday, 10:01 AM   #1562
perceval is offline perceval  Taiwan
perceval's Avatar
Originally Posted by xrk971 View Post
I was surprised by how affordable the racetrack woofer is from Madisound is $42ea. My concern is that the 84dB SB65 may not be able to keep up with the two woofers. In parallel as 4ohm load, they have about 92dB sensitivity at 2.83v. If we account for a circa 5dB baffle step loss, thatís 87dB at 2.83v. That would match an 87dB 10F or a B80 much more. But then you donít get the nice aluminum dome tweeter like top end of the SB65. Maybe a waveguide can buy +3dB and get the needed 2-3in setback?
There was a nice and gentle downward curve in my sim. and it was about 88dB for the woofers, and 85+dB for the SB65. Should be a very easy speaker to listen to.
Old Yesterday, 08:49 PM   #1563
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
I just designed a WWMWW with four of the SB15’s and a 5MR450NDY as wide band mid tweeter. It’s a TL with F3 of 40Hz and F6 of 33Hz and solid 90dB at 2.83v and 1m sensitivity after baffle step losses. Seems to look pretty good as 1st order BW XO at 1100Hz electrical but acoustic at 800Hz. This is a custom order for a DIYA member who says he may post a build thread. It sure looks interesting though. Max SPL is 113dB at 33Vrms.
4ft tall x 10in wide x 15in deep. Huge tapered TL vent exit (like PMC) at bottom.
Not surprisingly, the vertical polars look pretty decent.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old Yesterday, 10:09 PM   #1564
kornnylike is offline kornnylike  United States
I just designed a WWMWW with four of the SB15ís and a 5MR450NDY as wide band mid tweeter. Itís a TL with F3 of 40Hz and F6 of 33Hz and solid 90dB at 2.83v and 1m sensitivity after baffle step losses. Seems to look pretty good as 1st order BW XO at 1100Hz electrical but acoustic at 800Hz. This is a custom order for a DIYA member who says he may post a build thread. It sure looks interesting though. Max SPL is 113dB at 33Vrms.
Yep just place my order for the SB15.
A gift to myself.
Thanks X
Old Yesterday, 10:46 PM   #1565
Got Foam?
xrk971's Avatar
A gift to myself.
Thanks X
This will be fun - you might want to start a new thread for this once drivers get in and you start cutting wood.
Old Today, 12:17 AM   #1566
Tell us more, xrk. Did you select the PRV mid/hi? I gotta say four per box came to mind, Elsinore style. My first decent larger system had 5 8" woofers in an ugly column with the Audax 1.5 mid and piezo tweet.
10F/8424 & RS225-8 FAST Ref MonitorHide this!Advertise here!
The Nautaloss Ref Monitor xrk971 Full Range 673 12th November 2018 05:42 AM
Scan-Speak Discovery 10F/4424G / 10F/8424G BHTX Full Range 12 25th January 2017 09:32 PM
Dayton RS225-4 & Peerless SLS 8 in woofers, Linaeum, Coaxial omarmipi Swap Meet 9 28th November 2006 05:10 PM
T-Line for Dayton Ref 8" (RS225) dunderchief Multi-Way 20 7th November 2006 08:31 AM
FS: Aurum Cantus G2si Ribbon tweeter (pair) *used* & Dayton 5" ref midwoofer mmdb Swap Meet 1 29th April 2005 09:32 PM
