A Study of DML's as a Full Range Speaker
Old 8th April 2015, 05:09 PM   #41
Soldermizer is offline Soldermizer  United States
Soldermizer's Avatar
The difference between a lousy marksman and a constipated owl: the marksman shoots and shoots but never hits.
Old 9th April 2015, 12:49 AM   #42
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
That looks like a sub woofer driver. Cat food cans also make great heat sinks when bolted to TO220 MOSFET's. You have the makings of real shaker here. Looking forward to how coroplast works. You should get something out of them after being busted for pulling campaign signs off the road
Old 9th April 2015, 01:08 AM   #43
Yes it is a cheap car sub. I should try it with a coroplast but the biggest i have is about 18x24". I guess it won't hurt for experimentation. Or, I may just screw them to my loathsome "home entertainment center" ...
That reminds me...I need to call my shyster, ahem, attorney ... I was offered (and accepted) a "pre trial agreement" which apparently means I pay fines, do minimal community service (20 hrs) and the charges go away. Apparently the signs WERE there illegally but I was in the wrong to remove them ("petty theft"). None the less, 2016 beckons and we shall see...
Old 9th April 2015, 02:03 AM   #44
CLS is offline CLS  Taiwan
As can be seen in the photo of post #41, modding an ordinary driver into a DML exciter, the difficulty is in connecting the VC to the panel.
The VC of a cone driver is deep under the frame, one has to extend it long enough to be higher than the front surface of frame. So it'd be better if the frame is cut to free up the VC.
And then, to mount it on the panel, it needs additional external support to float above the panel. Some soft gasket on the existing frame might work (if not being cut), but not ideal. Those are going to be damping points and too close to the VC.
Eventually, I think it's not very cost effective to do such mods. It can be done and it'll make some sound, of course. But for better performance, proper exciters are worthy. And, actually they are cheap enough.
Old 9th April 2015, 04:57 AM   #45
Jim G is offline Jim G  Canada
Hi Guys, Interesting discussion re: home made exciters. Seems to me to be a lot of work for an uncertain result since PE has exciters that are so cheap. Some of the best are 8-14 dollars and one per panel is all you need. I have been playing with this stuff since 2009. Most important is the panel material. Current best is EXP or EPS but only if sanded and treated with thinned PVA glue. If this is done natural sound is the result. If not it sounds like plastic. ( I doubted it too) but sanding and treating is a must. If you want full range sound the panel needs to be large. A decent exciter and properly treated panel will give you sound that once you get used to the different presentation will cause you to dump your horns, various boxes and OB's. I would urge you not to dismiss years of experimentation available over on Audio Circle-- Open Baffle--NXT Rubbish Think Again. Thin ply can sound good too. Sorry X but foam core seems to be over damped and doesn't have the stunning clarity.
Old 9th April 2015, 05:04 AM   #46
Got Foam?
xrk971's Avatar
Note to self: order exciters on next PE order placed...
Can the pink XPS foam home insulation sheathing work? 1/2 in thick ? Needs to be sanded and PVA painted on?
Old 9th April 2015, 05:08 AM   #47
Hi Jim,
Thanks for the tips.
As to foamcore, it needs treatment to sound good, too. PVA coated, curved, and driven at the front surface (as my latest build) can bring life to it.
Before attaching driver to the panel, tapping on it and listen to the sound would be a simple test.
It should be clean and crisp, without excessive ringing. Think of those thin wood boards on various musical instrument, without the resonance of the box.
Old 9th April 2015, 05:37 AM   #48
Hi , CLS Is there a link to your latest build?
xrk971 Yes the pink XPS is good. Here it is 3/4 inch thick and available in 2'x8' pieces. Sanding and PVA a must. Sanding makes a mess so would be nice if not necessary but there is no way around it sonically. There is a thread on the go at PE tech talk forum pg 2 --DIY Flat Panel Speaker Love. They are making the pink XPS black with ink and some interesting mounting methods for the panels. Worth a look.
Old 9th April 2015, 07:12 AM   #49
perceval is offline perceval  Taiwan
perceval's Avatar
Great suggestions.
I was thinking coroplast with a sheet of mylar glued to it.
Or some fiberglassing composite. I have access to fiberglass and resin on the cheap, having done a couple of surfboards with a buddy.
And just in time, I thought, as Parts Express introduced cheaper economy shipping for international customers, but their system doesn't ship to a PO Box nor support Chinese characters, as my address is impossible to translate in English (not in a way that the package would actual reach me!).
Amazon ships to PO boxes, so I'll have a look there!
Old 9th April 2015, 07:32 AM   #50
Jim,
Here you are: http://www.diyaudio.com/forums/plana...ml#post3302597
A Study of DML's as a Full Range SpeakerHide this!Advertise here!
Full Range Voice Range single speaker and enclosure loninappleton Full Range 23 9th May 2014 12:14 AM
Proposal for a full range speaker radio Full Range 20 23rd April 2014 06:03 PM
Design Study: Full Range Line Array Dumbledog Multi-Way 5 27th October 2013 01:45 PM
Full range speaker package. perceptionchanges Swap Meet 1 15th July 2013 04:08 AM
Full range active speaker zebra100 Full Range 10 24th August 2009 12:28 PM
Copyright ©1999-2019 diyAudio
